02-17-2021, 11:27 AM   #1
ivanvernon's Avatar
K-1 battery cover
Does anyone know any way to purchase a Pentax K-1 battery cover? I have checked with Precision, and they say they do not sell parts. I cannot find anything on eBay or Amazon nor even by just googling the entire internet. Any assistance will be gratefully appreciated.
02-17-2021, 11:38 AM   #2
Otis Memorial Pentaxian
US Camera may have one. They are no longer able to get parts from Ricoh, but will fulfill from residual inventory while stock lasts.
USCamera | Parts Downloads Light Seals | Cameras Lenses More | HomeUSCamera | Knowledgable – Large Inventory – Fast Shipping
02-17-2021, 11:54 AM   #3
Please PM me,
02-17-2021, 02:03 PM   #4
ivanvernon's Avatar
Thanks Steve. Unfortunately, that is the first place I checked and they have no supply or idea of how to get supply on this and other similar Pentax parts.
02-17-2021, 09:30 PM   #5
Not a Number's Avatar
Try Advance Camera in Oregon. They won't sell you parts either but are (or was) an authorized Ricoh repair service for non-warranty work. Their rates are usually significantly lower than Precision's even if they have to send the equipment to Precision (in some cases).
02-18-2021, 03:58 AM   #6
ivanvernon's Avatar
Thank you. I have solved my problem as a kind member is sending me a cover from his damaged parts camera.
04-18-2021, 03:30 PM   #7
I had my door snap in half when the camera fell from a table. When I had the door open when the battery was charging.
I used plastic model cement to glue the two pieces together. And it worked! So depending on your damage, that might help.
04-18-2021, 04:34 PM   #8
ivanvernon's Avatar
QuoteOriginally posted by SirTomster Quote
Thank you. I also fixed mine using a sort of magic glue, and then a kind member sent me an intact part, so I have two solutions.
04-18-2021, 07:03 PM   #9
JimJohnson's Avatar
Location: Summer:Lake Superior - Michigan Winter:Texas Hill Country
QuoteOriginally posted by ivanvernon Quote
Bless this good friend. I suspect he is the same person who supplied me with an AF button. I won't give his name as he chooses to help on his terms where he has the part.
04-19-2021, 06:13 AM   #10
ivanvernon's Avatar
QuoteOriginally posted by JimJohnson Quote
Yes, he just wants to help and does not care about payment or even expressions of appreciation, but it is very much appreciated any way. The world needs more people like him!
04-25-2021, 12:10 AM   #11
For the record which cement did you use? They are based on different solvents some of which may not work on the resins used in the camera case. Typical solvents are xylene, toluene and MEK.
Thanks
04-25-2021, 03:25 AM   #12
ivanvernon's Avatar
Thanks
Apologies, but I did not do it myself. I had a jeweler do it for me. Alas, it has broken again, and now I will use the unbroken part as a replacement.
04-25-2021, 01:30 PM   #13
Thanks
It was Tamiya cement for models.
04-25-2021, 04:46 PM   #14
JimJohnson's Avatar
In my experience, depending on the type of plastic, the plastic specific mixed epoxies are the better repair adhesives, and the UV hardened materials are perhaps the best. That said, in every case, pull-strength is stronger than shear-strength (bending/twisting).
04-25-2021, 06:59 PM   #15
Model glues or cements work by melting the plastic and forming a weld or probably more accurately a meld (combination of melting and welding).. The classic tube model airplane glue is toluene mixed with styrene. The dissolved styrene gives the glue body and provides the welding material. Bottle or "liquid" model glues contain less styrene or may even be almost pure solvent. Typical solvents are toluene, xylene, Methyl Ethyl Ketone (MEK) or acetone. Tamiya extra-thin model cement is 50-50 butyl acetate and acetone.
Model kits are usually made from styrene / polystyrene which isn't a very strong plastic - it is rather brittle and cracks or shatters easily. Anyone who has dropped their Spitfire MkII on a concrete floor will know what I mean. If the solvent won't dissolve the plastic being glued the weld will only be as strong as the styrene used in the glue.
PVC pipe glue/cement is typically MEK mixed with ABS plastic. ABS is much stronger than styrene so PVC pipe glue should give a stronger weld.
Super glues or cyanoacrylates form bonds with the joining surface and cures as an acrylic. It requires moisture to form the bonds and plastic chains. UV cure cyanoacrylates can form stronger bonds through faster and more complete curing as long as the UV can penetrate throughout the material.
battery, k-1, k-1 battery, pentax service, repair, service, warranty
ME Super battery cover won't fit moggi1964 Film SLRs and Compact Film Cameras 16 02-12-2021 11:18 AM
Quick and dirty fix of broken battery cover lotech Pentax K-3 & K-3 II 5 02-04-2021 08:03 PM
Pentax Spotmatic, battery cover corroded shut tlwyse Film SLRs and Compact Film Cameras 13 12-21-2020 05:24 PM
All times are GMT -7. The time now is 10:51 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
