03-09-2021, 11:10 AM   #1
tripod collar issues on 70-200mm f2.8
Hello, I wasn't sure how to post a question to get some help with my Pentax 70-200mm f2.8 lens. I love this lens, but have had some real issues with the tripod collar coming loose at the lens connection. I am a professional sports photographer for high schools and colleges, so am moving around, running around a lot with my camera/lens on a monopod, so the tripod collar is essential. I have had it repaired once by Precision Camera Repair via Ricoh/Pentax, but in less than a year, it is already very loose again. Can I just glue the loose part that only stays attached to the lens collar and doesn't need to move ever? Please help, as time is of the essence. Thank you so much!
03-09-2021, 11:18 AM   #2
QuoteOriginally posted by loyalt Quote
I experienced the same thing, except I didn't need to sent mine for repair because I understood the problem before damaging the collar. My first reaction would have been to tighten the bolt more, but after examining the construction I found that the origin of loosening came from two small screws. Luckily I didn't force like most people might tend to do. I added a piece of aluminum foil to act a soft joint and tightened the two small screws again (without forcing too much), no glue, just dried mounted. Now fixed and didn't come lose again. And since the problem was the same (same construction) for the tripod collar of my D-FA 150-450 , I also fixed it, and never had to sent it for repair.
03-09-2021, 11:31 AM   #3
Otis Memorial Pentaxian
I added a piece of aluminum foil to act a thermal joint and screwed again.
You lost me there. I know what a thermal joint is and what aluminum foil is, but am probably not alone in wondering how you fixed the loose collar fitting. Might you elaborate?
03-09-2021, 12:36 PM   #4
I think he added a tiny piece of aluminum foil to the screw holes. Enough to add some "bite" to the threads. That's what I'm getting from it.
03-09-2021, 02:10 PM   #5
QuoteOriginally posted by gatorguy Quote
In which case...Loctite 220 (for small diameter...assuming tapped threads are not toast) or maybe Loctite 222MS (similar, but lower strength)?
03-09-2021, 02:13 PM   #6
could you add a picture of you're fix, i also have the 150-450 and wonder of i could get the same problem.
03-09-2021, 02:33 PM - 1 Like   #7
I have to pull the lens out of its bag.
The collar assembly is made of three parts:
- (1) one circular part that goes around the lens body
- (2) a small plate that is screwed to the circular part (1) by two tiny screws (1.5mm screws get all the weight of the lens, even more when camera is attached, by the way..). Big handle, big lens, with 2 tiny screws between them.
- (3) a handle that slides into part (2) and locks by turning a side bolt
Both D-FA 70-200 and D-FA 150-450 collar systems are designed the same way so that the handle can be easily removed without requiring any tool and a trapezoid (not sure how it's called in English, "dovetail" or something like that) lock to eliminate mechanical play when tightened. On both of my 70-200 and 150-450, some mechanical play occurred between the small plate (2) and the circular part (1), but at first sight it felt like the handle (3) wasn't locked tight enough, leading user to try to tighten the handle (3) more strongly and break that part in doing so. Luckily I didn't damage mine, but I know others have. So, I unlocked the handle and separate it completely. Then I unscrewed plate (2) completely and added two layers of kitchen aluminum foil between plate (2) and the flat area of (1) so that the softer aluminum material makes the two surfaces between (2) and (1) joint well over the whole surface of the plates when tightening the two screws again, so that there is not mechanical play anymore. And now, I super happy because there is no play at all between the handle and the lens, ensuring the lens doesn't move when mounted on tripod.
03-09-2021, 03:49 PM   #8
Thanks for that explanation Biz. I have that lens and will keep it in mind
03-09-2021, 04:44 PM   #9
Paul the Sunman's Avatar
I've had no such problem with either 70-200 or 150-450. Must check them tonight!
03-10-2021, 12:01 AM   #10
This has me completely flummoxed! On both my dfa* 70-200 and DFA 150-450, the "small plate that is screwed to the circular part" is attached by FOUR screws, not TWO.
Is this what we are talking about? It seems very firmly attached to me.
03-10-2021, 09:09 AM   #11
QuoteOriginally posted by Paul the Sunman Quote
yes 4 srews not 2. Sorry i did this stuff last year and did disassemble my lens for this post. My mistake. Yes 4 small scrws. I hope the OP understand the idea of the fix.
---------- Post added 10-03-21 at 17:10 ----------
Right. On my lenses these screws got lose after using the lenses for about one year.
03-10-2021, 09:18 AM   #12
Just checked my 150-450, it is very solid, no movement noticeable at all.
03-10-2021, 02:32 PM   #13
Thank you for the responses. I have had the small plate with the four screws come off completely, with broken screws, so sent in to Precision Camera Repair for almost $400.00 fix and 3 months in the repair shop. That was last year around this time. It is loose again, so I wondered, other than the aluminum foil fix, if a bit of glue could be used to permanently attach the plate to the round collar, since you don't have to ever remove it for use with a mono/tripod?
70-200mm, collar, f2.8, help, issues, issues on 70-200mm, lens, lenses, pentax service, post, repair, screws, service, tripod, tripod collar issues, warranty
Improved tripod foot for 300mm f2.8 with iShoot collar? MikeyBugs95 Pentax Camera and Field Accessories 10 12-30-2020 12:31 PM
D-FA 70-200 Tripod Collar Replacement Base AZGMDale Repairs and Warranty Service 5 11-26-2017 02:38 PM
Lens Hood and Tripod Collar for Takumar 200mm f/3.5 Preset hopkins802 Pentax SLR Lens Discussion 46 09-17-2017 03:18 AM
Tripod collar for DA 200mm f/2.8 skyoftexas Pentax SLR Lens Discussion 2 04-13-2014 09:36 AM
All times are GMT -7. The time now is 11:00 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
