Originally posted by Not a Number So it would seem that in North America the preferred method of repair by Ricoh is to replace the entire assembly.
It would seem, but is it really what is done?
Who knows!
In reality it is the most idiotic approach to replace the diaphragm control block!
The problem is to bring that near to any person not having done that work themselves, i.e. just knowing about it "in theory"!
1. The culprit is just the solenoid.
If the sparkplugs of your car are not functioning anymore, you don't replace the whole engine!
2. The work to replace the whole block is way way more intensive (and with risk to do more harm than good) and 100% unnecessary....
again: sparkplugs have aged.... whole engine replaced?
If under warranty: Yes, it brings money!*
But what is very easy is to swap the solenoid but claim that one has swapped the complete block.
Nobody is going to disassemble that Pentax to check!
Originally posted by Not a Number What the procedure in Europe, Asia and Australia is I couldn't say. As I recall none of the reports of "factory" repairs from Australia, UK, France or the Netherlands stated what was replaced. I don't recall any reports from Germany about Ricoh authorized repairs on the problem.
Which repairs from France or Netherlands do or can you recall.
Ricoh France knows that it was just the solenoid and that in the K70 a modified solenoid was used.
And which authorized repairs from Germany do you know?
Based on which evidence?
Invoices going back to 2018 from "authorized repairs" in Germany state:
Ausgeführte Servicetaetigkeiten: "Kamera überprueft, Magnet erneuert; Blendensteuerung repariert."
translated:
Service activities carried out:
"Check of camera, replacement of magnet, repair of aperturecontrol"
I had some of those on my workbench after they failed again.
The solenoid had been changed. That was all.
I can tell when the complete diaphragm control block had been replaced.
Simply because the screw for the solenoid is then left instead of right!
Also usually the date of manufacture is written on the block and very few other parts slightly differ.
I also can tell by the laquer on the solenoid-fixing screw and on the soldering itself.
Again: The work involved to change the whole block literally is about the same if you change the engine of a car when just he sparkplugs need to be replaced!
Just that an engine can really be old, but the control-block doesn't really age.
I just don't believe in fairy-tales!
* With a little more detailed check:
1. K50 resrandall:
Warranty
2. K70 OldChe:
Warranty
3. SharkyCA: This was a true exchange of the complete block and
not under warranty
4. gump: replacement of Assy:
no warranty but € 245,67
when it could have been done within 20min.
5. ramseybuckeye:
Warranty
6. mgvh:
Warranty
7. UncleVanya:
Warranty
So up to here we have
7 cases and
5 done under warranty.
8. GuitarGuru76: Worth to check the complete story, not the best advertisement for precision and their work:
a) K-S1 with shuttercount of just 800 had several faults:
K-S1 LCD Failure - PentaxForums.com
it came back
"terribly treated by precision" and
had to be repaired again. A almost new K-S1 came back and looked rough and aged.
b) K-S2 bought 2-nd hand in the forum. After shuttercount 2000 failed. Repair by precison for 180$ not on warranty
So they charge $ 248 for swap of the complete "assy", wonder what was really done for $ 180 !?!
could be anything, nobody checked/disassembled their works!
Except with SharkyCA's K70 we don't know what really was replaced!
By the way: It is just USCameras.com not selling the single solenoid but only the complete block!
Ricoh doesn't sell to private people anyway. So the argument that the solenoid is not available: not only thin ice but actually steam
Of course the solenoid itself is available to the official repair places!
