Hi.
I have a Sigma 500mm f/4.5 EX DG APO in Pentax K-mount. The lens mount plate is quite worn, the groove that locks the lens to the camera is almost worn out. Please see attached picture. I have contacted Sigma here in Sweden and they can’t get the part I need. Do any of you have an idea of where I can find one? I belive the part number is 5678P60.
I have tried to replace it with mounts from two other Sigma lenses from the same timeframe, but they do not fit. Thankful for any help.
Best regards, Henrik
Reason: Fixed
