Originally posted by 35mmfilmfan No mishtake - you start off with that then move to 0000 steel wool. Works every time
Originally posted by 35mmfilmfan Mike, which swabs would you recommend, please ? I used some from Ebay before and had to take my K20D to LCE for a proper job afterwards !
I've used a few different ones and not had much trouble with any except for those with defined, protruding edges - "teeth" - at the edges of the swab, that are designed to straddle the sensor. I found those to be a real pain. The last lot I bought - and I've been very happy with them - are these:
https://www.cameraclean.co.uk/p/alpha-premium-kit-13pcs/
I bought the 17mm versions for my APS-C cameras, and the 24mm for full frame. In reality, you can use the 17mm for both if you do more than one pass (which is perfectly safe if you use a blower and gel-stick first
), as the cloth extends slightly beyond the edges of the plastic "spatula". I've always used Eclipse cleaning fluid and that may have something to do with my personal record of successful cleaning. Plenty of people have told me that other, cheaper fluids work just as well, but I've never tried them. I
think I'm still on my original tiny bottle of Eclipse, though it might be my second - I can't recall for sure. Anyway, the important thing is, having placed two or three drops along the edge of the swab's cloth, I give it a few seconds to soak and evaporate a little before cleaning. I don't want the swab wet, as such - just damp (I use the same trick with Zeiss optical wet wipes for my lenses and filters, as they're almost dripping wet out of the packet and leave streaks if used that way). Then, I apply gentle pressure - more than gravity, but not heavy pushing; just a light pressure - as I wipe from one end of the sensor to the other, flip the swab over and do the same again - and sometimes, a third and fourth pass if I think it's necessary.
I have some very small sensor swabs (like mini lint-free cotton buds) I bought years ago from an Australian company for cleaning my Q and Q7. On one occasion I used one of those with Eclipse fluid to eradicate a stubborn spot (not sure what it was) on a GX-1L I bought used from eBay... otherwise, the regular swabs have done the trick for me.
PM me if you need more info or if I can help in any way
EDIT: I thought I'd add this, just in case it's not obvious... By getting rid of all loose dust and debris using a blower and gel-stick, and using good-quality swabs with good-quality cleaning fluid, there is nothing to "scrape" against the sensor when wet-swabbing, so multiple passes and even a bit of over-enthusiastic pressure aren't a problem. It's when the sensor still has dust and/or debris on it that swabbing poses any real risk.
