Originally posted by aldo taddia I think so the aattack is safer, isn't it?
The concern over plastic bayonets is usually quite unfounded, IMHO. With many lenses - those with plastic bodies - the metal bayonet is simply screwed into plastic, so in the case of a serious bump or drop, the bayonet screws strip the threads in the body. In such an instance, you might even argue a plastic bayonet might put less stress on the body's mount as it's more likely to break and leave the body undamaged. The one potential benefit of a metal bayonet is that, over time, it might wear less than a plastic one if the lens is fitted to and removed from the camera very frequently. In reality, though, the plastics used are very hard-wearing. On the few lenses I own with plastic bayonets, I've not noticed any significant wear - nothing worse than rub marks.
TL;DR - a metal bayonet looks nicer, but probably doesn't offer any real benefit over a plastic bayonet for a lens that's fitted with one...
