08-30-2022, 07:26 AM   #1
Loose Hot Shoe
I have a loose hot shoe on my Spotmatic SPII. Do I need to remove the top to tighten this? I found a youtube video showing this for a Spotmatic. Is the SPII roughly the same?
IPhone 12 mini  Photo
08-30-2022, 08:29 AM   #2
Not a Number's Avatar
There is little difference between most of the Spotmatic models with flash shoes. However it looks to me that the sheet metal is damaged so it may take a lot more repair work than simply tightening down some screws.
08-30-2022, 08:33 AM   #3
sergysergy's Avatar
It looks like it is broken? It is missing the back part of the black (plastic?) attachment. In order to tighten it you have to remove the metal sheet on top of the flash. that should give you access to the screws.
08-30-2022, 08:40 AM   #4
QuoteOriginally posted by sergysergy Quote
You're right, it is missing that back piece of plastic. Since I rarely need to use a hot shoe, and have other cameras I can use if I need one, could I just remove this and cover the holes where the hot shoe was?
Edit to add: I was able to tighten down the screws and take out the wiggle. Would it cause problems to use it like this, missing the back piece?
08-30-2022, 08:58 AM   #5
sergysergy's Avatar
I think you should be ok!
08-31-2022, 07:52 AM   #6
Stick a small piece of duck tape over the hole so dirt won't get in.
pentax service, repair, service, shoe, spii, spotmatic, warranty
Seeking screws for Hot Shoe Adapter F and Off Camera Shoe Adapter F Nathaniel C Pentax Camera and Field Accessories 6 08-07-2020 03:13 PM
Pentax hot shoe adapter + off shoe adapter - any limits on the flashes used? MSL Flashes, Lighting, and Studio 4 10-25-2014 06:13 AM
Wanted - Acquired: Wein Hot Shoe to Hot Shoe Safe Sync HSHSB 990-560 excanonfd Sold Items 0 08-26-2010 10:56 AM
Wein Safe-Sync Hot Shoe to Hot Shoe Iowa Tom Pentax DSLR Discussion 1 09-12-2009 09:20 PM
All times are GMT -7. The time now is 03:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
