Originally posted by Not a Number You could try checking the service manual if it mentions the problems. There could be a fault somewhere in the system even if the lights come on.
A contact cleaner might make the problem worse unless you use one that is made for moving contacts or the surface lubrication would get removed.
Service manual can be downloaded here:
https://www.pentax-manuals.com/manuals/service/servicemanuals.htm Thanks for the link to the manual, I'll check it out.
I found a video on youtube (
) where he seems to have the same problem as me, fixed exposure in OVER, and the cause seems to be in the dial itself, mounted wrongly or pasted due to time without use. I don't have the tools needed to make the repair, I'll have to send it to a technician and maybe indicate the possible problem.
Anyway, if anyone had the same problem and knows the solution, I'd be grateful if you could share your experience.
