Originally posted by E-man Pleeeeeeze make sure you have a fresh set of good quality batteries in the camera when you update the firmware. You can irrevocably 'brick' the camera if it cuts out while you're upgrading. This happened to me several years ago with an *ist-DL. The experience was so traumatizing that I did not attempt a firmware upgrade again for the next three years.
I bought a set of Lithium AA batteries for this attempt and a used CPU tower with Windows 7 to download the upgrade to perform this task My laptop doe not have an SD card reader slot. I cringe at the thought of upgrading firmware and so my K-S2 and K20d are still running the original firmware. In this case I am assuming there is a problem with the original firmware and hoping this might cure the problem. So far I am close to $130.00 trying to solve this problem on a $58.00 camera.
