Show Printable Version 150646 Likes Search this Thread
04-02-2018, 01:20 PM   #15421
BruceBanner's Avatar
QuoteOriginally posted by Tas Quote
Having spent a lot of time living in the bush and working in roles that required me to advise other people of the 'widow maker' potential of gum trees, I do not understand why anybody would choose to allow one to grow in the vicinity of their home.
Granted some gums are worse than others, but if you see a heavy branch growing horizontally from the trunk, or even on a 45 degree angle you have to assume that gravity will eventually win. Especially if there's a strong wind event after an extended dry period.
Glad to hear there were no munchkins around when the power lines were knocked down.
Tas
Yeh a similar branch fell outside where I park (my car is the red subby in the background of shot number 4), and totalled the vehicle, happened 15mins after getting the kids out of the car after school pick up time!
They always they seem to break in dry hot, still weather conditions. Unfortunately this is the Blue Mountains, if we went around taking every mighty tree out that could (and will) have large branches falling off, then 50% of the mountains would be gone, it's just unrealistic as well as too expensive for many! I guess it's just something you have to accept if you live in the bush. In fact council wouldn't have let you take down any gum tree without good reason till just very recently after the last bad bush fires (destroyed 200 homes) then they bowed to public pressure and allowed the removal of any tree within 10m of the property without approval needing.
Ironically removing trees within 10m of the property from a bush fire perspective does little to nothing to help prevent bushfires or defend property really, but does stop falling branches from killing people and cars lol.
QuoteOriginally posted by pweindich Quote
To my knowledge there is only one 35mm ltd., the Pentax DA 35mm Macro limited.
Was it this one; SMC Pentax-DA 35mm F2.8 Limited Macro Reviews - DA Prime Lenses - Pentax Lens Reviews & Lens Database
or this one?; Pentax 35mm f/2.8 Macro Limited HD DA Review
I take it it's similar to other HD, different coating, usually resulting in better flare and perhaps bokeh control but star bursts are not as good with the HD compared to regular ltd?
Would be interested to see some non cropped K-1 shots with it, and if PP can correct the vignetting easily etc.
With the first stair shot, I take it you shot wide open at f2.8 then?
Sorry for all the questions, but with great shots come great responsibilities! hehe
04-02-2018, 01:29 PM   #15422
QuoteOriginally posted by BruceBanner Quote
Ah I am very sorry, you are right of course, they remade the HD versions, mine is a regular non-HD version. Though I think the only difference is a different lens coating (not sure). The first stair shot is at f2.8 yes.
I attached a completely unaltered image from the 35mm at f6.3. I have to pull up the corners by about two stops to make them even, but then again it really only affects the very extreme corners. The 70mm ltd. I have as the HD version and that shows no vignetting at all as far as I can tell (also a fabulous lens imo).
04-02-2018, 01:36 PM   #15423
Do you have the RAW or original jpg (with EXIF) for that shot still? I 'saved image as' and tried to load it into LR and see if I could use a Pentax Lens Profile to correct vignetting etc, but alas I believe the file has lost its EXIF as I'm not even able to select 'Pentax' as a brand for the lens profiling.
Quite curious to see if with the 35mm you can solve the corners without cropping in PP.
Ta!
04-02-2018, 03:24 PM - 3 Likes   #15424
eaglem's Avatar
A nice kind of Orange
04-02-2018, 05:09 PM   #15425
RobA_Oz's Avatar
QuoteOriginally posted by repaap Quote
So, how bad is vingetting? I suppose that for 'macro' use it is no problem, but how about outside. I'v been pondering about getting wider macro than my 90 mm. so FF that would be DFA 50, or? this 35 mm limited..?
Experience differs on this. I get vignetting which can usually be removed in post, but admittedly by using extreme removal on PS sliders, but others actually get actual clipping of the corners, even without the lens hood. I can only explain the difference as either being due to manufacturing tolerance, presumably with internal masking, or that I simply haven’t used the combinations of aperture and focal distance that others have, to observe the effect.
In any event, cropping in-camera (either to APS-C or Square mode) or in post removes the problem, where it occurs. Cropping in post-processing doesn’t seem to be necessary to the extent of the APS-C frame.
PS – while the DA35 Limited is as fine a piece of glass as you’d expect for its designation, the FA50/2.8 Macro is similarly worthy, even though it doesn’t carry the same branding, albeit that its build isn’t to the same standard as that of the 35 or the DFA100/2.8 Macro.
04-03-2018, 03:12 AM - 1 Like   #15426
RichardS's Avatar
QuoteOriginally posted by LeRolls Quote
I was trying to compose I witty comment, but my mind has gone to mush. A lovely girl.
---------- Post added 03-04-18 at 20:22 ----------
My kitten is taking over the right side my desk. I'm waiting for the colder months for him to migrate to the thermal efficiency nightmare 300w Class A amp on the left side of my desk.
Pentax K-1 - SMCP-K 55mm f/1.8 @ f/1.8 ISO 400 1/60th
Love your kitten shots, but class A is cool.
---------- Post added 03-04-18 at 20:48 ----------
Mainly to do with multiples of 10 being significant due to having 5 fingers/toes on each hand/foot. If we had 4 fingers and toes then 800 would be the milestone! hehe
(nice shots by the way
512, I think. And, while we're at it, the new millenium, started in 2001, not 2000.
04-03-2018, 05:39 AM - 7 Likes   #15427
Just Chillin' (DA *55/Pentax K-1)
04-03-2018, 08:25 AM - 6 Likes   #15428
Irix Thingy ƒ/5.0 15.0 mm 1/160 ISO800
QuoteOriginally posted by gaweidert Quote
Eric,
That is a well used old four shaft "barn frame" loom. Love the polish on the back beam. Lots of thread over it's lifetime. If the yarn was hand spun and woven while still "in the grease" it will be soaked with lanolin. My wife got her first loom in 1979. I have learned a lot by sheer osmosis and by having to do some repairs on older looms and spinning wheels.
Thanks, it is great to see your perspective. The cool thing about Heritage Village is that most of the artifacts are not just a hodgepodge of randomly displayed items, but are a collection from the original owners and from the people of the area that were actually used in those re-located buildings and homes on the property, so it lends authenticity and tangible connection to the past.
Eric
QuoteOriginally posted by fs999 Quote
I'm sure he is laughing it up, where he is Thank you !
Nice points of view for that sewing machine !
A new one I would say, for mkI upgraded and mkII of course...
Thanks Frederic, I think you are right. And... that is a great looking drink, I want to grab it!
Eric
04-03-2018, 10:43 AM - 5 Likes   #15429
fs999's Avatar
QuoteOriginally posted by Erictator Quote
Wonderful shot !
Eric
Thank you Eric !
FF Mode • 100 ISO • Pentax DA* 55mm F1.4 SDM
FF Mode • 800 ISO • HD Pentax DA 560mm F5.6 ED AW • Pied Woodpecker
Crop Mode • 100 ISO • Pentax DA* 55mm F1.4 SDM • Topaz Labs Texture Effects 2
04-03-2018, 11:12 AM - 4 Likes   #15430
acoufap's Avatar
Two Sculptures - One Nature Made in Color, One Man-Made in Black & White
... both K-1 • DFA28-105
04-03-2018, 12:05 PM   #15431
Master of the obvious
savoche's Avatar
QuoteOriginally posted by acoufap Quote
Some contrast to savoche's pictures - from mountains to the sea.
I'd take your sea over my moutains any day! This winter has been far too long...
Here is couple from our spring time. Still waiting for one.
Yeah, this spring would have fit better around Christmas time. But hey, at least the daylight is back
04-03-2018, 12:39 PM   #15432
QuoteOriginally posted by savoche Quote
That daylight is nice. Soon it will be crazy..
04-03-2018, 02:55 PM - 15 Likes   #15433
DimC's Avatar
The Irix thingy* 15mm !
Fantastic lens on the K1.
PS : I've deleted the picture #2, processing was wrong, using new Lightroom DNG profile that are oversaturated in blue and magenta on some of them. I need to double check all those profiles.
*See Erictator pics.
PENTAX K-1  Photo
PENTAX K-1  Photo
Last edited by DimC; 04-03-2018 at 11:12 PM. Reason: Deleted the photo #2 - wrong processing
04-03-2018, 03:04 PM - 9 Likes   #15434
QuoteOriginally posted by DimC Quote
I really like what I see with the 15mm Irix. When i see pics like this and others with the Sigma Art 35mm 1.4 it makes me feel as though I have to give up on the idea of Zooms and just stick to Primes!
Here's a pic from Easter Monday taken with the FA50mm;
Little Trekker
04-03-2018, 03:47 PM - 8 Likes   #15435
LeRolls's Avatar
« k1 vs k1ii | - »
camera, copy, crop, da* 200mm f2.8, dslr, f2.8, focus, friend, full frame, full-frame, images, k-1, k-1 ii, k1, pentax, pentax k-1, pics, pm, post, post your k-1, review, sample, shots, squirrel, time
Post pictures made with your worst lens! LensBeginner Pentax SLR Lens Discussion 27 08-02-2018 10:27 AM
Post your K5IIs pictures here... SECELEE Pentax K-5 & K-5 II 2 02-21-2015 09:30 PM
There should be a post your K-30 pictures thread memo90061 Pentax K-30 & K-50 3 10-30-2012 02:06 AM
Thematic Post your winter pictures ohce Mini-Challenges, Games, and Photo Stories 10 03-22-2012 06:17 PM
Who can post pictures in the post your pictures category? Sitting Bull Troubleshooting and Beginner Help 3 12-14-2010 05:41 AM
All times are GMT -7. The time now is 09:13 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
