Originally posted by ogl Anyway - it's nonsense to make CROP MODE on the dial if there are only TWO mode - FF and APS-C.
Yes, it does seem a waste of the command wheel if there are only two options.
Plus as the the selector dial is recessed from the camera back, it is not well located ergonomically for one handed operation. You can't easily rotate the selector knob around with your thumb alone, nor index finger, whilst holding the camera up to your eye. You need to move your whole hand up on top of the camera to rotate the selector knob.
Originally posted by ogl As I understand there is more quick access to choose FF or APS-C mode thru programming buttons
With some FF cameras (eg Nikon), you can assign a button on the body. Press the Fn button to choose image area mode, rotate rear command dial to choose the ratio (FX/DX/etc).
Pentax should let users choose one of the Fx1/Fx2 buttons to switch crop modes, and allow other little-used buttons (eg AE-L) to be re-assigned too. (From what I can tell so far, the K-1 has no buttons that let you select crop-mode).
IMHO, for the K-1, Pentax should let every button on the camera (and grip) be re-assigned to almost every camera function. Would greatly expand the control flexibility of the camera, and work well with the expanded U1-U5 saved user modes.
