Hi all,
So I hope no one's planning to shoot manual flash in liveview mode on the K-1...
I'm not a K-1 owner, but I played with one today at Lozeau, one of the larger photo stores in Montreal, where the K-1 has landed. I wanted to see how the K-1's behavior compares with my K-3. Result: I believe they behave exactly the same. Meaning that (unless I missed something) it's impossible, in liveview, to disable exposure preview in the LCD screen. In fact, the K-1 goes further than the K-3. While the K-3 will only dim the LCD by up to -2 eV when it
thinks your shot will be underexposed, the K-1 goes at least to -5 eV, and an almost totally black screen. The impossibility to turn this off is very irritating when shooting manual flash in liveview! In such circumstances, the camera artificially dims the LCD because it thinks the shot will be underexposed. But it won't, since the (manual) flash will fire!
With the K-3, I run into this all the time shooting macro in liveview with a manual (Yongnuo) flash. The artificial dimming of the LCD is really irritating (see a
previous discussion). On the K-3, the only workaround I know of is to set aperture using the aperture ring on the lens rather than controlling it from the body. (Of course, this assumes you're using a lens with an aperture ring. Otherwise you are S.O.L..) Setting the aperture with the aperture ring disables exposure "preview" in liveview mode on the K-3. I did not have a chance today to test if this workaround also works on the K-1, but I would think it probably does. Of course, this workaround has drawbacks: 1) No aperture value in the EXIF, and 2) often there are fewer stops on the aperture ring than possible values when controlling aperture from the body.
So, Pentax, if you're reading this, please allow the option to disable exposure preview in liveview mode on your new flagship camera. This should be a simple firmware fix.
