Originally posted by mtngal But I haven't tried taking one from a completely different camera manufacturer, I wonder if that can be the cause of issues and why he gave that warning?
Yes I was aware of this. I used sony camera before and sony install a database in the SD card to keep track of multiple things. I always format my card when switching to different systems.
Originally posted by funktionsfrei This sounds as if the SD card reader used in the PC isn't compatible with SDXC cards
My card reader is compatible.
Originally posted by funktionsfrei Instead of attempting to format the card in the card reader, I recommend doing so via the camera. The camera's firmware is constructed to be standard-compliant, and it is thus well abled to format a memory card.
Actually that's not such a good idea. I used to do it all the time because I was assuming manufacturer of camera know what they are doing internally to the card and should be fully compatible. When my K-1 format cards it render them useless, like I explained in my original post. I also have the firmware up to date.
Only workaround I found is to format on my computer (running archlinux), and to never ever format card in my K-1, I proceed to just "delete all images" in camera. I have had no problem since then.
