Originally posted by Tjompen1968 I am doing my own "testing" right now to see what happens. A TIFF file is the same as a RAW with a different files extention. Maybe the info in the TIFF tells adobe that it is a pixel shift. If I take a normal PEF file and just rename to TIFF it still opens in ACR with the same color etc as if PEF. It applies the sharpening I have told ACR to apply as a base when K-1 PEFs are opened. I do not know, trying to understand this so that I can benefit the most from it. So far everone else is getting wopping results and mine look quite dull.
If I open a pixel shifted RAW in Lightroom 5, I think it just opens the initial RAW image of the series of 4 and the image looks fine, but nothing spectacular. If I open it in DCU and click on the enable PS button, suddenly the image looks really sharp. I often will do a little tweaking of the image at that point -- bump shadows a little and export it. That's usually all it takes, although I do import the TIFF image to Lightroom and do any adjustment needed. You can try it in combination with any of the image presets in DCU -- landscape seems to bump saturation a fair amount, while natural tends to be more flat.
This is a PS image taken with the DFA 100 macro (full size on Flickr)
