Originally posted by Shanti using either DA*300,DFA 150-450, or DA70 +1.4TC ,AFS & AFC mostly single spot,sometimes 9 pt. all options turned off, RAW(DNG) + Jpeg L FF mode with crop mode maybe 30+ FPS so it only happens in FF mode. latest FW 1.10,fresh battery or grip attached
I assume this is intermittent, not all the time?
I just ran a test with those settings, with RAW only I get 13 images before the buffer fills. With RAW+ I get 11. I ran 5 tests with no issues. Dual 64gb SanDisk Extreme Pro cards.
You might try with only one card, or with a different card. If it is intermittent I wonder if there is a card fault that causes the burst to end? Maybe try a card format if you have not done so.
