Show Printable Version 16 Likes Search this Thread
06-04-2016, 06:38 AM   #61
Sticky around
"but the one thing that keeps tripping me up is that I keep accidentally bumping (and changing) the Drive Mode."
Set menu item C20 to #2. This defaults the d-pad to changing the focus point instead of the drive mode. To change the drive mode you will need to press the AF change button first.
Not just this helpful little ditty, but all of these cool workarounds (and the reasons for them) are crying out for a compiled sticky.
06-04-2016, 07:00 AM   #62
jatrax's Avatar
QuoteOriginally posted by seanix Quote
- No physical SR on/off button (I'm slowly getting used to this).
You can set either of the FX buttons to SR on/off. I use FX2 for this. You can also set one of the tiles under the INFO button to SR on/off. I have the bottom right tile set to it. Press INFO spin the e-dial to select on/off.
06-04-2016, 11:31 AM   #63
QuoteOriginally posted by solar1 Quote
I think in cf 20, Option 1, the little button may act as a toggle so that the 4-way controller items remain available until the little button is pressed again to make AF point selection available... With Option 2, the 4-way controller switches immediately back to AF point select after changes have been made to drive mode (or whichever item on the 4-way controller) and OK is pressed.
I prefer the behavior of Option 2 but mention how Option 1 seems to work in case its function as a toggle was not apparent..
The menu item descriptions are too cryptic and only by trying both could I understand the meaning.. honestly, even after knowing what the options do... the description still makes no sense.
06-08-2016, 10:30 AM   #64
micromacro's Avatar
Perhaps someone already mentioned that.
I love when screen flips back in place if I forget to do it. It has been a couple of times when I leave the screen out then carry the camera around on the neck, and hear "click": the screen goes back itself if my body pushes the screen.
body, bunch, button, camera, cameras, cap, composition, contrast, dslr, fa43, feature, full frame, full-frame, k-1, k1, lens, liveview, pentax k-1, phone, placement, playback, results, review, view
Lloyd Chambers - I think he likes the K-1 HopelessTogger Pentax K-1 & K-1 II 5 05-28-2016 04:36 AM
The ethics of 'likes' in an online photo competition Wild Mark General Photography 80 03-03-2016 01:10 PM
K-5II Likes and Dislikes rjm Pentax K-5 & K-5 II 8 05-26-2015 03:10 PM
User interface (menu) likes and dislikes einstrigger Pentax DSLR Discussion 6 11-09-2010 05:47 PM
Anyone else dislikes the comparisons of the K-7 to the D5000/T1i or D300/50D even? NothingInCommon Pentax News and Rumors 60 06-15-2009 11:14 PM
All times are GMT -7. The time now is 12:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
