If your main target is to wirelessly control the K-1 and have liveview (that means: you are fine with the actual image files still going to the SD card) then you are not restricted to using a smartphone / tablet.
On a Windows PC or Mac just install Bluestacks (All About Bluestacks) and within it install the Image Sync App for Android.
During my trying I had to click on the app option "process
without wireless connection" to
make it work using the wireless connection. Somehow weird, but once I knew it, fine.
Now you can do anything you can do on your tablet including liveview.
I first tried Andy and the remote control worked, but no liveview.
If your PC is using LAN and also has a Wifi hardware: First disconnect the LAN cable (you will loose Internet access obviously) and connect to the K-1 using Wifi. If you later reconnect the LAN cable, both things work in parallel (internet for the PC and wireless from app to K-1.
With some manual actions you can even transfer the files from the camera to your windows file system (just google this about Bleustacks).
