06-11-2016, 02:58 PM - 2 Likes   #16
I'm on my tablet and tbh hate typing on it so I'll keep it short and just add these test shots I made a few weeks ago with the HD version of the lens. Hope it helps.
1. Effect of hood (don't use it)
2. Vignetting
3. Vignetting close/far and open/stopped down
And test shots are all well and good but this is an actual photos off the type I like to take with this lens. Nothing wrong with it at all... This is at minimal focus distance.
06-11-2016, 03:06 PM   #17
Na Horuk's Avatar
Btw, does the DA 35mm macro have a baffle on the back, as the DA* 60-250mm does?
06-11-2016, 03:21 PM   #18
Na Horuk's Avatar
QuoteOriginally posted by dcshooter Quote
Every Pentax K lens has a baffle of some sort or another.
Touché. But is it restricting the image circle, in this case?
06-11-2016, 03:40 PM   #19
micromacro's Avatar
Yep, the hood is a killer. I would prefer to have an option for that lens with wider hood which is not build-in.
Hope Ricoh will start "rebrending" Pentax lenses for FF soon.
06-11-2016, 07:56 PM - 1 Like   #20
Sandy Hancock's Avatar
To put this one to bed, I just went out into the garden to get some test shots. I'm pretty sure there are two types of vignetting which take place here.
Please ignore the sensor dust and flare, as the hood was (of course) fully retracted for all shots.
First, there is what I will call optical vignetting, which is worst wide open, and occurs from MFD to infinity. It looks to be significantly more than half a stop to me (at least at infinity focus, where it almost extends to APS-C frame), but should be correctible in post processing.
MFD f/2.8
Infinity f/2.8
Stopped down, the optical vignetting is gone at MFD, but at infinity there is what I shall call physical vignetting, where the leading edge of the lens casing (not the hood, which is in all cases fully retracted) impinges into the field of view. Only a crop will fix this.
MFD f/22
Infinity f/22
And a couple of intermediate focal length shots to demonstrate how the two types of vignetting interact.
Landscape f/2.8
Landscape f/22
Bottom line: the Pentax-DA 1:2.8 35mm macro limited is NOT a full frame lens, except stopped down at close focal distances.
06-12-2016, 12:28 AM   #21
That's not image circle vignetting. It's you taking a picture of the inside of your hood! If you pull the hood back in, the image circle actually does cover the entire sensor. That's why you are counterintuitively getting the more defined edge when you stop down - the DOF is increasing, so the insides of the hood are closer to being in focus.
If you look at Joost's images above, you can see what I mean.
See sandys reply above. Hood in, high f number and focus at longer distan es gives hard vignetting. For macro its a completly different story
06-12-2016, 01:53 AM   #22
One thing that has gone unmentioned: sharpness and contrast hold up very well in the extended FF area though not in the extreme corners.
Personally I have no qualms about using this lens on the K-1 if it suits my needs but I will factor in that I might need to crop and/or remove some vignetting in PP. That is not a problem for me as everything goes through Lightroom anyway.
Basically: as with any lens you need to be aware of its character and traits and therefor of its restrictions.
06-12-2016, 02:15 AM   #23
MFD f/2.8
Infinity f/2.8
MFD f/22
Infinity f/22
Landscape f/2.8
Landscape f/22
I can confirm this, still the lens is very usable in FF mode in my opinion.
Here a sample in FF mode with F8 without correction of vignetting:
Same picture vignetting corrected, but beware that the darkened corners also have a drop in resolution which is not fixed:
In worst case one can slightly crop the picture if the lower resolution in the corners disturbs one.
I linked some other samples in this thread already:
https://www.pentaxforums.com/forums/169-pentax-full-frame/291365-da-lenses-fu...ml#post3641826
06-12-2016, 10:44 AM   #24
even tho its not the best landscape lens anymore due to vignetting. Macro works great and I still love my DA 35 macro ltd
06-12-2016, 02:56 PM   #25
RobA_Oz's Avatar
Thanks for that demonstration, Sandy. The weather's been so adverse here since my K-1 arrived, that I haven't had the inclination to go out and do some more testing.
A post script to this might be, that the DA35/2.8 macro may evolve into a D-FA35/2.8 macro, with some optical redesign. Even ignoring the variety of tastes in macro focal lengths, the low weight and general performance of this lens is enough to earn it a place for a redesigned version in a future lineup of full frame 35mm format lenses.
06-12-2016, 03:52 PM   #26
QuoteOriginally posted by melander Quote
Absolutely.
Don't get me wrong - it's still a fantastic, even uniquely wonderful lens.
06-12-2016, 11:03 PM - 2 Likes   #27
I have used the 35mm Ltd lens a few times recently, with the Pentax K-1. My experience is the following: (a) Quite a lot of vignetting if you use the incorporated hood (b) a small amount of vignetting if not using the hood. I enclose a couple of photos to illustrate this. The waterfall was at f16 to reduced the shutter speed. The panoramic shot was two photos stitched and taken at f8. Both photos taken using a tripod. Neither have been corrected for vignetting, which is slightly noticeable, but not significant for me. The image quality seems excellent to me, across the frame. Regards, John
PENTAX K-1  Photo
06-13-2016, 02:36 AM   #28
RobA_Oz's Avatar
With the variations that people are showing here, I can't help wondering if we're seeing production tolerance differences or even production variants that are responsible for those differences. I'll run some tests on my own sample now, to see what it produces.
06-13-2016, 02:53 AM   #29
QuoteOriginally posted by johnmb Quote
It's a nice shot; the dense physical vignetting is only not a problem here because the corners are already dark. My test shots were designed to demonstrate the problem, this seems designed to hide it.
The overlap conveniently removes the vignetted corners of the right and left corners of the left and right image respectively. The vignetting in the remaining corners looks rather weird given the aspect ratio of the resultant stitch. You'd get a much better result in crop mode stitching four or five images in portrait orientation.
At the size they are posted it is impossible to say with certainly, but the edges look pretty fuzzy to me.
---------- Post added 13-06-16 at 07:27 PM ----------
QuoteOriginally posted by RobA_Oz Quote
I reckon the results in johnmb's post are entirely consistent with mine, for the reasons stated above. By all means do your own tests though
09-15-2016, 12:16 PM   #30
I've found that if crop to 24mp at 3:2 aspect ratio there's no obvious vignetting, thus getting a k-3 worth of pixels with the greater scope to push in post. Handy option to me.
corners, da35/2.8 macro, depth, depth of field, dslr, field, frame, full frame, full-frame, image, k-1, k-1 ii, k1, length, lens, lenses, macro, pentax k-1, photos, post, production, shot, tests
DA35 2.8 limited - I can't believe nobody bid on this one.. K57XR Pentax SLR Lens Discussion 11 05-09-2015 11:48 AM
FA 31 limited vs DA35 Macro 2.8 limited peterjcb Pentax SLR Lens Discussion 19 05-07-2014 03:21 PM
For Sale - Sold: K100D Super, 18-55, DA21, FA28, DA35/2.8 macro, DA40, FA50/1.7. FA50/2.8 macro dgaies Sold Items 14 09-18-2011 03:46 AM
All times are GMT -7. The time now is 05:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
