04-14-2022, 02:35 AM - 1 Like   #1576
QuoteOriginally posted by adabo Quote
Which Pixel Shift mode do you use? With or without motion correction?
Just to expound a little more, these are the different Pixel Shift options:
(1) Pixel Shift (motion correction off) -- this requires tripod support and a completely still scene. Any areas of motion will show as artifacts. If you are shooting RAW you can motion correct with post processing, even if you don't have MC turned on in camera.
(2) Pixel Shift with motion correction -- motion correction can be done in camera or in post, but basically, with motion correction you replace any areas of motion with masked in areas from a single one of the four images you shot. Pentax's DCU uses the first image, but Raw Therapee will allow you to choose any of the four. I think it is important to note two things. First, any scene with lots of motion will require masking of the whole image and you are better off shooting a single image. Two, hand held simply won't work. Pixel shift requires a pixel level adjustment and that is not possible hand held. Having motion correction turned on in the camera simply means that the jpeg will have motion correction applied to it. If you are shooting RAW it won't make a difference one way or the other.
(3) Dynamic Pixel Shift -- this is a hand held pixel shift that is only available on the K-1 II. It isn't terribly useful -- it can only be processed in camera and doesn't allow for RAW image shooting. It takes a long time to process per image, but does reduce noise and improve sharpness for a jpeg image.
My personal rules of thumb are that you should use a tripod and have a still scene and use either the self timer or a remote to trigger the camera for best results. I do typically shoot RAW, process in Raw Therapee and generate a TIFF image that I use as my baseline image for further editing. Raw Therapee has a feature where you can see the motion mask and it lets you know how much movement occurred in a scene. If more than 60 or 70 percent of an image shows motion, then there is probably very little benefit to processing it as a pixel shift and you should just take the best of the four images to work with.
04-14-2022, 03:26 AM   #1577
I think the issue of moving subjects is generally over stated if Rawtherapee is used to develop raws.
Motion won't negatively affect the image at all compared to normal single shot.
However those parts with motion won't benefit from pixelshift either. Thing is that even if you shoot a cycle race there might be static parts of the frame benefitting from pixelshift. Wether it's worth it is another question.
04-23-2022, 03:18 AM - 3 Likes   #1578
Night on the Ohio River (DFA 24-70mm/pixel shift)
05-01-2022, 03:40 AM - 2 Likes   #1579
Sunrise (DFA *50/pixel shift)
05-02-2022, 03:36 AM - 3 Likes   #1580
Beautiful Tree (DFA 24-70mm/pixel shift)
Crossroads (DFA 24-70mm/pixel shift)
05-07-2022, 07:24 AM - 2 Likes   #1581
Petersburg Jail (DFA 24-70mm/pixel shift)
Dawn on the Ohio River (DFA 24-70mm/pixel shift)
05-08-2022, 03:36 AM - 3 Likes   #1582
Horse Farm Before Dawn (DFA *50/pixel shift)
05-14-2022, 07:04 AM - 3 Likes   #1583
Country Road at Dawn (DFA *50/pixel shift)
05-15-2022, 11:47 AM - 2 Likes   #1584
Bridge (DFA 24-70mm/pixel shift)
05-21-2022, 04:22 AM - 2 Likes   #1585
Country Road (DFA 24-70mm/pixel shift)
05-21-2022, 05:29 AM - 1 Like   #1586
Thanks for continuing this thread Rondec. I'm going to make it a plan to give PixelShift a go when out on one of my wildlife hikes, if not this weekend then next. Great images sir.
05-27-2022, 04:43 AM - 2 Likes   #1587
Sunrise and Tree (FA 31 limited/pixel shift)
05-28-2022, 02:22 AM - 1 Like   #1588
Country Road at Dawn (FA 31 limited/pixel shift)
05-29-2022, 03:13 AM - 2 Likes   #1589
Sunburst on the Road (DFA 24-70mm/pixel shift)
05-30-2022, 03:48 AM - 1 Like   #1590
Between the Tracks (DFA 24-70mm/pixel shift)
control, dcu, distagon, dslr, flickr, full frame, full-frame, image, images, k-1, k-1 ii, k1, movement, night, pentax, pentax k-1, pixel, pixel-shift, pixels, ps, road, sec, secs, shot, thread
Pixel Shifted Snoqualie Falls using 24-70mm Pentax AwesomeIan Pentax K-1 & K-1 II 20 07-01-2016 09:32 AM
How to display pixel shift images. TroutHunterJohn Pentax K-3 & K-3 II 8 11-10-2015 07:58 AM
Sensor shifted composite shot of 40MP resolution MichalW Pentax DSLR Discussion 23 01-17-2015 03:44 AM
Shifted from Canon to Pentax ruwanal62 Welcomes and Introductions 5 03-15-2014 11:06 AM
Image count on K200D has shifted to a high number Stratario Pentax DSLR Discussion 6 06-29-2008 05:52 PM
All times are GMT -7. The time now is 10:43 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
