07-14-2016, 01:39 PM - 1 Like   #31
QuoteOriginally posted by Namajam Quote
We need an acronym page! DCU?
Do you only do the Pixel Shift (PS) in DCU and the rest in Lightroom? I strictly use Lightroom for my workflow. I tried to do PS in lightroom but not sure if I seen much of a difference.
Digital Camera Utility? It is the software that comes with a Pentax K-1 and it has the capability of developing RAW pixel shifted files, which Lightroom 5 doesn't really. I usually apply the motion correction, set the preset applied to "Natural" and dial the fine sharpening down 3 clicks. That seems to give me a pretty neutral file that I can do what I want with.
07-14-2016, 01:42 PM   #32
I'll give her a try! Thank you!!
07-14-2016, 02:16 PM - 10 Likes   #33
k-1 31 ltda
07-14-2016, 03:53 PM   #34
Is needed processing the raw image into a Tif? Or can be process into a JPEG?
Thanks
07-14-2016, 04:19 PM   #35
QuoteOriginally posted by Antonio Andrade Quote
Thanks
I process into a 16bit tiff then import into Capture one (9) and work with the tiff
07-14-2016, 07:32 PM   #36
Thanks
You can do a JPEG as long as you like the way it looks. But then you might as well just shoot out of camera jpegs. The TIFF file gives a lot more depth to work on if you want to lift shadows or do some selective sharpening.
07-14-2016, 08:13 PM   #37
disconnekt's Avatar
QuoteOriginally posted by Tjompen1968 Quote
PS used for repro... Negative from Pentax 6x7
Awesome to see someone using PS to digitize B&W film, was wondering how the results would look.
07-15-2016, 06:09 AM - 8 Likes   #38
K1+M28/3.5
07-15-2016, 06:26 AM   #39
QuoteOriginally posted by pinholecam Quote
K1+M28/3.5
Amazing!
07-15-2016, 06:34 AM - 2 Likes   #40
Tucker Lake.
07-15-2016, 10:50 AM - 3 Likes   #41
fs999's Avatar
FF Mode • 100 ISO • Sigma Art 18-35mm F1.8 DC HSM • Pixel Shift
07-16-2016, 06:50 AM - 16 Likes   #42
One from Steptoe Butte in Palouse (washington state). I took both PS and non-PS shots here, and the PS shows a dramatic difference here in dynamic range, the foreground was pretty dark so there is still noticeable noise from lightening the shadows. But I have to say I absolutely love the quality of the noise flecks in the K-1, they are more fine-grained and so not as distracting to the eye and more like film grain (as others have noted already). This is the pixel shift version:
07-16-2016, 07:31 AM   #43
QuoteOriginally posted by carolina_sky Quote
One from Steptoe Butte in Palouse (washington state). ...
Yes, I think images like this might be the type for which I would try pixel shift as much as any other type. I wondered if the colors near saturation and maybe the transition to clipped would be better..
I have read some posts that working with a 16-bit TIF is as good as working with RAW file. This may be for many purposes, but I don't think TIF will allow highlight recovery in the way a RAW file would. I wish the pixel shifted images could be exported from DCU or Silky Pix as some format that would retain the flexibility of a RAW file.. that the greater detail visible in either a TIF or JPG could be repackaged into a RAW-type format for further processing...
07-16-2016, 07:54 AM   #44
richmondthefish's Avatar
Granted I am looking at this on a crappy monitor at the moment but looks like you're getting more detail from the Pixel shift than the Epson scan?
07-16-2016, 07:57 AM   #45
Pål Jensen's Avatar
Terriffic image. I would have cropped a bit at bottom of the image.
control, dcu, distagon, dslr, flickr, full frame, full-frame, image, images, k-1, k-1 ii, k1, movement, night, pentax, pentax k-1, pixel, pixel-shift, pixels, ps, road, sec, secs, shot, thread
Pixel Shifted Snoqualie Falls using 24-70mm Pentax AwesomeIan Pentax K-1 & K-1 II 20 07-01-2016 09:32 AM
How to display pixel shift images. TroutHunterJohn Pentax K-3 & K-3 II 8 11-10-2015 07:58 AM
Sensor shifted composite shot of 40MP resolution MichalW Pentax DSLR Discussion 23 01-17-2015 03:44 AM
Shifted from Canon to Pentax ruwanal62 Welcomes and Introductions 5 03-15-2014 11:06 AM
Image count on K200D has shifted to a high number Stratario Pentax DSLR Discussion 6 06-29-2008 05:52 PM
All times are GMT -7. The time now is 07:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
