08-03-2016, 07:51 PM   #1
120 -400 mm Sigma not working on K-1 , BUT works on my old K-3.
My sigma 120-400 will not work on my K-1, but it does works fine on the K-3. The camera will not do anything with that lens attached.
PLease help .
08-03-2016, 08:50 PM   #2
See my reply here:
https://www.pentaxforums.com/forums/190-pentax-k-1/319937-k-1-troubleshooting...ml#post3730662
08-03-2016, 09:08 PM   #3
I own the 135-400mm Sigma, it doesn't have a problem.
08-04-2016, 05:28 PM - 1 Like   #4
Steinback's Avatar
Just had my 120-400 HSM updated by Sigma Canada. They swapped the mount and updated the software on the lens control board but it still doesn't work on my K-1. The camera locks up as soon as it is turned on and the battery has to be pulled to reset the body. If/when they have a software fix that works I will send the lens back to Sigma again.
08-04-2016, 07:09 PM   #5
120-400mm Sigma is not working on K-1 BUT works great on K-3 ?
Thanks , so its a brick for now .That's not a good news .
08-04-2016, 07:17 PM   #6
Steinback's Avatar
Check the thread I made after doing some more in depth testing with a friend. Taping over the HSM contacts on the lens allowed it to work properly in manual focus mode with auto aperture control.
08-04-2016, 07:34 PM   #7
Thank you I'll try that .
10-05-2016, 07:49 PM   #8
Steinback's Avatar
To follow up my 120-400 went back to Sigma a second time, they updated the board and now the autofocus works. The fit of the new mount to the body is a bit sloppier than it was with the original mount but otherwise things worked out alright. Even though the invoice for the original repair had a line item for re-chipping the lens apparently it didn't happen.
10-06-2016, 08:36 AM   #9
Thank you , I sent my lens 120-400 mm to Sigma yesterday, I'm hoping that they can do something to make it work on my K-1 .
11-06-2016, 05:21 PM - 1 Like   #10
My sigma 120-400 IS FIXED , send it to Sigma they replace the board and mount .Thank you Sigma
06-05-2017, 12:27 PM   #11
QuoteOriginally posted by Steinback Quote
I recently had mine updated with a new mount and firmware and can say it still locks up the K-1 as soon as you take a picture, it's endlessly showing the write to card light on, until you pull the battery. I hope Sigma know the new FW does not work.
06-05-2017, 08:00 PM   #12
Steinback's Avatar
Send the lens to Sigma a second time. After the second trip in and a board swap my lens works. It seems like Sigma doesn't have a K1 to test on so they try one fix, send the lens back, then do a different fix that actually works on the second trip.
07-25-2017, 11:24 AM   #13
Thanks
120-400mm f4.5-5.6 dg, dslr, full frame, full-frame, k-1, k1, mm sigma, pentax k-1, sigma
Nature couple Birds with sigma 120-400 & K-3 DarkShadow Post Your Photos! 14 05-05-2015 01:13 PM
Manual lens works fine on K200d but not on K-3 simon_199 Troubleshooting and Beginner Help 17 03-29-2015 08:39 PM
AE teleconverter works on K-01 but not other bodies? geomez Troubleshooting and Beginner Help 15 07-27-2013 05:18 AM
Stop-down metering not working with extension tube on K-5 (works on K10d) Beau Troubleshooting and Beginner Help 3 09-13-2011 04:37 AM
About to Pull the Trigger on Sigma 120-400 but... [Double Post] flash1100 Pentax SLR Lens Discussion 5 09-09-2009 12:44 PM
All times are GMT -7. The time now is 10:33 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
