Originally posted by Class A Here's what one needs to do in order to get the
Fuji profiles as a choice for the K-1 in C1:
Copy the files into
C:\Program Files\Capture One 9\Color Profiles\DSLR\
(you may have to adapt the path if you did not use the standard installation location)
and rename the "FujiPro2" part to "PentaxK1" to yield, for instance "PentaxK1-PROVIA_SRGB.icc".
You'll then find "PROVIA_SRGB" as profile choice for the K-1 in C1.
BTW, I find that "Film Standard Extra Shadow" works best as a "Curve" choice with the Provia profile.
Thats good stuff i,m on a mac so had no idea how to do the PC version
for the mac do the name change to the ICC profiles as above and then you need to
click "go" on finder menu bar at the top ,then hold down ALT key a folder call library will appear in the menu
go in there and drop them in
library/colorsync/profiles
then reboot the machine and they will appear in the profile for k1 after the reboot ....if you put them in this folder you get the roll over preview and all they won,t vanish when you do an up date to C1
will be interested to see how other fair with these ..i,m going to try and get my luts converted into ICC ..if it works out i will post them
