10-17-2016, 11:48 AM   #31
My 24-70 showed mixed/different results for 24 and 70 mm. I decided to calibrate for 70 mm at the end. Stopping down the 24 side one stop will cover up all issues.
There was something like 6 steps between both ends.
Btw a tele lens may have a narrow DOF that requires optimum placmenet, but the amount of barrel movement from close to far focus is fairly wide. A wide angle lens requires much less truning to go from close to far focus huts in absolute terms a small misalignemnt of lens elements in the back is more significant than for a tele lens.
10-25-2016, 03:23 PM   #32
What are the best methods for testing autofocus accuracy?
10-29-2016, 04:55 AM   #33
DimC's Avatar
QuoteOriginally posted by jls74d00 Quote
I've been using this method for a while on all my Body/lens combination, works well.
AF microadjustment for the 1Ds mark III, 1D Mk3, 5D Mk2, 7D, 1D X
10-29-2016, 09:50 AM   #34
UncleVanya's Avatar
QuoteOriginally posted by DimC Quote
I can't imagine being 50x the distance of your 300mm lens from the screen inside our house.
10-29-2016, 10:19 AM   #35
DimC's Avatar
Ha-Ha true !
It's 5X not 50x, which is still a long distance I agree. But for my 70-200mm I found out a way to to have 7-8m and it was fine.
10-29-2016, 12:18 PM   #36
UncleVanya's Avatar
Ha-Ha true !
No. it is 50x and some people use 30x.
Note - Camera-to-subject distance should ideally be no less than 50 times the focal length of the lens. For a 50mm lens, that would be at least 2.5 meters (25m for a 500mm)
10m is 50x on a 200mm lens. At 7-8m that is over 30xso that should work fine.
10-29-2016, 01:22 PM   #37
DimC's Avatar
Yeah right !
I had no problem calibrating my lenses with that method, which is fairly simple.
12-09-2016, 02:12 AM - 1 Like   #38
I have been doing several tests, but in the end decided to sent the K-1 for calibration. I was not getting the pictures I got from my K-5 IIs, which I expected to be at least the case. The amount of keepers was so low, I started to doubt my skills and became frustrated that I could not get a single worthwhile shot, while there is a thread here that has the most amazing shots. My shots were out of focus and even with SR turned on and 1/160 shutter time, I would get motion blur shooting with the 24-70...
The good news is, that my Pentax dealer is tremendously good, so I have handed in my Pentax K-1 and received another K-1 so I would not be without a camera! And this K-1 is a complete different experience! I get tack sharp photo's, even on my first outing when I did not even bother to calibrate my lenses on the K-1. Seagulls scaled to 100% are almost as sharp as the image I would get from my K-5 IIs!! I am loving this camera!
So now I hope that my own K-1 will return from Pentax and behave just like this one does!
12-09-2016, 08:40 AM   #39
You have a good dealer! I don't think my local pentax dealer even knows how to spell K-1.
12-13-2016, 11:46 AM   #40
I certainly have a good dealer, it is just a small shop with the owner helping you, makes everything much more personal, which I highly appreciate! Today I got a call from the owner, my K-1 is back from Pentax and the CCD sensor is replaced, the original one was not functioning properly. He will conduct now some tests to assess the sharpness before I am allowed to pick it up ;-).
I am so happy with this outcome!
12-03-2018, 03:46 PM   #41
DFA* 50 1.4: +8
DFA* 70-200 2.8: +8
Should i send it back for calibration (under warranty)? Also the grip ralltes a little bit.
12-03-2018, 04:11 PM   #42
pschlute's Avatar
QuoteOriginally posted by crash82 Quote
DFA* 50 1.4: +8
DFA* 70-200 2.8: +8
Why? You able to adjust within the tolerance.
autofocus, balance, camera, curve, dfa, dslr, focus, full frame, full-frame, k-1, k1, lens, pentax, pentax k-1, system
What was your first lens on the K-1 and what did you photograph with it? pathdoc Pentax K-1 & K-1 II 45 07-26-2016 05:54 AM
35mm Macro Fine Auto Focus Adjust - Does it work for you? smigol Pentax K-1 & K-1 II 4 05-19-2016 09:21 AM
What AF Fine Adjustments have you needed on K-1? Kennod Pentax K-1 & K-1 II 10 05-10-2016 06:57 PM
How to Fine Adjust for focus? keanex Troubleshooting and Beginner Help 20 02-13-2016 05:26 PM
Any way to adjust focus on K-50? keanex Troubleshooting and Beginner Help 3 01-07-2016 02:40 PM
All times are GMT -7. The time now is 07:08 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
