First frame after installing the firmware upgrade in my Pentax K-1 that adds the option of a 1:1 crop.
https://www.pentaxforums.com/forums/attachments/190-pentax-k-1-k-1-ii/327312d1475260122-standing-ovation-k-1-firmware-update-1-3-first_square.jpg
According to Adobe Camera Raw file properties, file size is 42.83 MB, dimensions 4912x4912, bit depth 16.
Handheld 1/15 sec. at f/8 with 15mm lens (which was designed for the APS-C format).
[File size reduced to 144 ppi and from 16- to 8-bit and converted to JPEG for convenient attachment here.]
I expect that this is about close as I am going to get to a 'full-frame' digital Hasselblad. The sensor area is 24x24mm
on the Pentax in the 1:1 crop, as compared to 56x56 on the film version of the Hasselblad. Smaller, but larger than the 13x13mm
of the micro four-thirds cameras.
The 15mm lens yields a diagonal angle of view almost five degrees wider than the Biogon on the Super Wide C. The Pentax DA 21mm
is one degree wider than the 50mm Distagon, and the Pentax 35mm Macro is one degree narrower than the 80mm Planar.
Bestest of all: Ricoh/Pentax just gave this update to us without charge or fanfare.
