Some tests:
USB OTG connection:
Samsung S7, v6.x... phone crashes into the boot loader, and it corrupts the camera card.
Samsung T705, v4.4.2... it works fine.
WIFI connection:
Both above devices work, transfer speed is 300kbytes/sec (only!). The app has the same bug on both i.e. you have to use the "offline" mode, having manually connected to the camera in Settings/wifi.
The camera is excellent, as is the 24-70 lens. But you people knew that already
I don't know if this is applicable but there is a number of camera "remote control" apps in the android appstore, and some of these may work with the K1. Has anyone tried them?
It would be useful to have a wifi-PC connection (currently not possible unless somebody writes some code to drive the JSON interface) but then again the USB connection obviously works perfectly with windows, and is very fast.
Correction: from here
https://www.pentaxforums.com/forums/190-pentax-k-1/330677-pc-desktop-tetherin...orks-well.html
there may be a windows solution.
