In my opinion that's not a bad price for a good example of the lens. They have a proven track record in astrophotography.
For what it's worth it should be noted the extreme importance of achieving perfect focus when taking photos of the night sky. The difference between a "good" versus an "excellent" photo can be as little as 10 microns. I read an article a few years back that stated that astrophotography is sensitive to changes of as little as 1/10,000th of an inch anywhere in the imaging train. That's the reason why I have dual speed focusers on all of my astrographs. I also built a special precision focuser for a camera lens I was using just in order to achieve perfect focus for astrophotography.
Here's a great article explaining the critical importance of perfect focus when taking astro photos.
The author used GoldFocus, the same software I use, and a Rigel Stepper Motor to control the focuser on his astrograph. For DSLR photos using a conventional camera lens a follow focus system needs to be employed. There are various automated and manual systems available depending on how much money you want to sink into astrophotography.
I've attached two photos of old setups I used a few years back. These photos were taken in my backyard when we lived in Texas. It gives an insight into the amount of equipment I use for taking astro photos. In the bottom photo the astro camera is not yet attached because I am letting all the equipment acclimate for at least an hour before I even bring out the photo gear out. I bring an 80mm f/5 achromat along in order to serve as a wide field spotting scope. This helps when I am searching for a specific object to image at focal lengths of 900mm or more.
In both photos half of the equipment I'm using was either custom made or heavily modified for my usage. I no longer have any of this gear as I've upgraded to more precision instruments customized over the years. I don't have any photos of my current setups to share but it's pretty much along the same lines as what I have in these photos but just newer.
obin
