Originally posted by southlander I think this only works for JPEG output so not much help for RAW users
True enough. WB data is recorded in the RAW metadata (inc. Multi-AWB), but not directly applied to the image until processed.
Problem with M-AWB is that not all RAW processors, I think, know how to handle M-AWB white balance. [As I understand it] M-AWB records different bits and pieces of WB all over the image, as the metering algorithm sees fit, and then stores those readings in the EXIF somewhere, whilst 'normal' camera WB just paints one WB setting over the whole image.
I suspect only Pentax Digital Camera Utility, and the in-camera RAW processing engines of Pentax and Ricoh cameras that offer M-AWB, know how to fully implement M-AWB when processing RAW's into TIFFs or JPEGs.
