12-30-2016, 07:02 AM   #1
New K-1 Won't take pictures
OK, I know I am doing something dumb, but when I turned my 4-day old K-1 on this morning, the F-stop indicator was flashing on and off (upper rh side of status screen), and the camera shutter does not activate. Help! It's almost sunrise! A couple other settings changed too, without my input - it is set to MF and single-spot metering.
12-30-2016, 07:04 AM   #2
normhead's Avatar
Did you try a factory reset?
12-30-2016, 07:04 AM   #3
Try to take your lens off and put it back on again. It sounds like there's a loose connection. If needed, also clean the lens mount.
If your lens has an aperture ring, make sure it's set to "A".
12-30-2016, 07:14 AM   #4
I did that and it fixed it. Thanks very much. Seems odd though - brand new camera and lens (Tamron 28-75 2.8)
12-30-2016, 07:22 AM   #5
D1N0's Avatar
Try cleaning lens contacts. This just looks like a bad connection. Maybe some grease got on it.
12-30-2016, 07:34 AM - 1 Like   #6
Rupert's Avatar
I have had similar "happenings" a few times and it was always caused by pushing some wrong button or combination of buttons by accident. Damn I hate it when it happens....it sends me into "Panic Mode". Old guys don't do good in panic mode...your blood pressure rises, you break out in a cold sweat, your face gets real red, and then that foul language starts to flow...which brings out Mrs Rupert and things go from bad to worse. Squirrels gather outside my windows and laugh while placing bets on when I will kill over dead......it is just a plain ugly experience all around.
Fortunately, I have learned to be more careful when handling my K1......I don't want to be holding it in my angry trembling hands when I kill over.....that kind of damage is not covered by warranty.
Regards & Glad you are up and running again!
12-30-2016, 08:06 AM   #7
UncleVanya's Avatar
QuoteOriginally posted by Parkfreeon6th Quote
Which "That" did the trick?
12-30-2016, 05:16 PM   #8
Paul the Sunman's Avatar
Most likely the lens did not click into place. There should be an audible click when you put it on.
dslr, full frame, full-frame, k-1, k1, pentax k-1
Pentax K-x won't take old lens? Sara Hanna Pentax DSLR Discussion 21 05-30-2021 12:25 PM
Pentax K-x Won't take photos auscop Troubleshooting and Beginner Help 13 05-30-2015 05:48 PM
My *istDS won't take pictures. MarioMilo Pentax DSLR Discussion 9 10-02-2013 10:36 AM
k-30 Battery won't take a charge? ccrookston Troubleshooting and Beginner Help 5 08-06-2013 06:33 AM
Like new Pentax-F 1.7x AF adapter with fungus that won´t show on pictures carrrlangas Pentax SLR Lens Discussion 9 06-06-2013 01:41 PM
All times are GMT -7. The time now is 06:04 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
