01-28-2017, 12:06 AM   #1
K-1's more than random overexposure with FAJ 18-35mm and FA Ltd 77mm
Hi,
My Pentax K-1 (bought last August through CR Kennedy, Melbourne) has experienced occasional overexposure (sometimes the whole picture was totally overposed). But I just thought it's an operating error and had ignored it until yesterday I had more frequent overexposure pictures (please see a few attached for comparison). I used two lenses as shown on the title. I used multi-segment exposure mode for those pictures and usually applied -0.7 exposure compensation or more.
Given your experience, I would like to know if this indicates a faulty camera or there might be an easy fix on my part. I read on another Pentaxforums thread about a similar problem with K-3 (https://www.pentaxforums.com/forums/58-troubleshooting-beginner-help/302516-r...d-16-85-a.html). Just as a background, I have a K-3 and never seem to have the same problem (maybe once or twice during the past few years), and I am now travelling and don't have K-3 with me to test whether it's the lenses' problem or K-1's problem. I shot K-3 often with FA Ltd 77mm and it seems all fine, but yesterday's consistent overexposure with the same lens on K-1 has me very concerned.
Any advice and help would be greatly appreciated.
CX
PENTAX K-1  Photo
PENTAX K-1  Photo
PENTAX K-1  Photo
PENTAX K-1  Photo
01-28-2017, 02:05 AM   #2
The fix is either manual exposure, or send the camera for repair.
01-28-2017, 02:35 AM   #3
Your ISO is different between shots in the EXIF data. Are you inadvertently changing it with the third dial on the K1?
01-28-2017, 02:47 AM   #4
Your ISO is going all over the place, from ISO 100 to ISO 3200. Limit it to a narrower range - eg ISO 100-800 perhaps. Plus your last FA77 image says you were using manual exposure plus manual WB.
Perhaps switch to centre-weighted average for your metering and see if that makes a difference.
01-28-2017, 04:06 AM   #5
oupps i did not see it was manual exposure... in that case I don't think it's a camera issue.
01-28-2017, 04:27 AM   #6
Otis Memorial Pentaxian
I remember your previous problem which definitely pointed to faulty aperture actuation, probably with the lens. In that case, the overexposure happened for photos having identical aperture, shutter, and ISO settings.
Based on the full EXIF, your photos above seem to indicate metering error (EV varies by factor of 4 on top pair). By any chance are you set up to have exposure follow focus point? (Focus point is "zone select, near left, single point", on the top pair, but framing is different.) You are using TAv mode and Av mode (presumed auto-ISO), so lazy aperture or aperture controller is another possible cause with the lens not fully opening between exposures.
01-28-2017, 04:34 AM   #7
The top two are TAv mode and the bottom two are Av mode (presumably auto-ISO). The metered EVs are way different between the top and bottom for each pair.
01-28-2017, 05:01 AM   #8
Just noticed that AE Lock was engaged for all four photos (???). Are you set to AE-L when AF locks or was the AE inadvertently locked at the wrong exposure before taking the photo?
01-28-2017, 05:22 AM   #9
Full EXIF from a straight-out-of-camera JPEG image would be nice to identify the camera settings. Hard to do that from the current stripped-down EXIF.
01-28-2017, 09:33 AM   #10
The posted photos are SOOC JPEG, though shot at ridiculously low resolution.* I was able to extract the full set of metadata from all four images using ExifTool.
* They may also be embedded thumbnails...both have full EXIF, IIRC
01-28-2017, 06:28 PM   #11
True. I should have EXIFTOOL'd them earlier. Lots of metadata indeed for a 50K JPEG! Probably about 10% of the byte count.
I also noticed AE Lock was active - eg on the last FA 77 image. Hence AE was 'frozen'. Easy to accidentally press that button.
01-28-2017, 07:59 PM   #12
I have had the same issue with my K1 but it only occurs about 1 per thousand pics.
01-28-2017, 11:58 PM   #13
Many thanks Steve for pointing that out. I just checked my camera custom setting and indeed "AE-L with AF Locked" was set as "On" (I might did this when doing some portraits a while ago but then forgot to change this back). I think that could well be the source of problem. I had thought that this would not affect exposure too much under the multi-segment (as opposed to spot) metering mode, but I may be wrong here, hence the exposed pictures (but then I rarely got under-exposed pictures under these conditions). I will do some new tests and see if changing "AE-L with AF Locked" to "Off" will fix the problem - fingers crossed. Thanks again!
---------- Post added 01-29-17 at 12:01 AM ----------
Many thanks for helping zero in on the AE lock issue. I will do new tests and report back if this is the problem.
---------- Post added 01-29-17 at 12:07 AM ----------
QuoteOriginally posted by BROO Quote
The second dial was set on Wifi and so I wouldn't be able to accidentally change the ISO between different shots through the third dial. But thanks for the reminder.
01-29-2017, 12:20 AM   #14
These pictures were shot with either aperture priority or TAv, not full manual exposure. Attached at the bottom is a screenshot of that totally exposure picture's shooting info as shown in Digital Camera Utility 5.0, which may be more accurate.
---------- Post added 01-29-17 at 12:25 AM ----------
Sorry Steve for the low-resolution pictures - I resized them before uploading onto the site just in case the larger file size slows down the uploading. I normally shoot both RAW and JPEG in maximum resolution.
01-29-2017, 02:03 AM   #15
Thank you all for the quick and very helpful replies and suggestions. I just did some test shots. When AE-L with AF was turned on, I again had over-exposed shots. When "Off", the exposures were consistently normal. So the 'On' setting for AE-L with AF seems to be the problem. It's a big relief that it's user error on my part. Many thanks again for helping out and I really appreciate it.
18-35mm and fa, ae, af, camera, dslr, exposure, fa, fa ltd, faj 18-35mm, full frame, full-frame, iso, k-1, k-3, k1, lenses, ltd, overexposure, overexposure with faj, pentax k-1, shots, tests, thanks
Any test shot with K-1 for FA 77mm DA* 55 and DFA 28-105? rlatjsrud Pentax Full Frame 9 09-11-2016 11:10 PM
For Sale - Sold: Pentax K-1 + FA 31mm Ltd. + FA 77mm Ltd. + DA 15mm Ltd. parkjoo000 Sold Items 3 08-23-2016 05:57 PM
Random overexposure with K-3 and HD 16-85 polar bear Troubleshooting and Beginner Help 11 03-18-2016 06:36 AM
For Sale - Sold: Pentax K-3, K-5IIs, FA* 85/1.4, FA 31/1.8, Sigma 15/2.8, DA 18-135, ... + MORE wullemaha Sold Items 13 09-04-2015 02:53 AM
For Sale - Sold: Pentax FA* 85 1.4; FA 31 Ltd Silver; FA 43 Ltd Silver; CZ T* 50 1.4 ZK and more... Immortal.Eternal Sold Items 13 08-06-2013 07:44 PM
All times are GMT -7. The time now is 04:30 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
