Jpegs work just fine.....like several have mentioned it depends on your setting adjustments, and your processing. In this shot the Jpeg is as good as the Raw for the intended purpose...which is not a billboard size print, just a downsized picture to be web posted. I have my settings adjusted to my taste.....use an old Elements7 program (with two dozen superb plug-ins
) and can do most every procedure that I can do with Raw processing.
It's fast and easy, the smaller files process faster and my end result is very often as acceptable as the Raw would be. I am not against Raw processing...it is useful and wonderful, just not always necessary.
Angry squirrel just before pouncing on a stray cat......Catdip tonight!
Want to make a subtle change to the lighting on his face? Selective lighting works as well on Jpegs as on a Raw......I use Light Machine..very handy Plug-In. K1 Jpegs process very easily!
Here is one where Raw and three different programs were used to get a half decent result. It was shot through my office windows, through a side window that has a charcoal colored fiberglass screen. Raw can help get all possible out of an otherwise wasted shot.
The first shot took less than a minute to process
...the second considerably longer!
Squirrels don't really care if it is Jpeg or Raw, just as long as they get their few seconds of fame on the internet, so the world can see their astounding "handsomeness" and unflinching bravery!
Regards!
EDIT: Forgot to mention.....for those that use Flickr, the Aviary is great for minor edits of a shot you have posted there but still needs a little attention. You can do quite a bit of adjustments in there and it is fast and easy.
Just a few quick clicks and I changed this one in contrast, focus, and brightness...
