02-21-2017, 06:45 AM   #1
K1 for live video?
I have a request to video a musician performance and stream it live on the internet, using Facebook.
I'd consider using the K1 for this with the 31mm. ( previous example -
Does anyone know if it's possible to use a K-1 in this way?
I was reading this interview/discussion that seems to suggest that live video through HDMI will also show the in-camera settings, is this correct?
Ricoh Q&A @ CP+ 2016: The Pentax K-1 design story; video feedback solicited; sub-frame lens test update
02-21-2017, 08:28 AM   #2
QuoteOriginally posted by dcshooter Quote
You can turn it off the info display using the info button. Note, the K-1 doesn't support clean HDMI out (i.e. the image will show compression artifacts), and you will chew through batteries really quickly, so an AC adapter is recommended.
Thanks. Do you have any examples of what compression artefacts will look like?
02-21-2017, 02:12 PM   #3
AFAIK - aside from a non-compressed signal, "Clean HDMI' is a function to feed a live signal from your camera's sensor through the HDMI without the on screen info overlay you see displayed on the back LCD.
Pentax has never had this ability.
So it would be unsuitable to send to a streaming device.
02-22-2017, 02:21 AM   #4
QuoteOriginally posted by Steve.Ledger Quote
Great. I guess I'll use a Sony Handycam or Canon 5D or similar ;-p
12-13-2023, 08:25 AM - 1 Like   #5
dotp's Avatar
Updating this thread. The K1 can be used for live streaming. There is a YouTube video (
) that shows you how to set it up and remove all the display info using the camera video mode, a power adapter, and a streaming card.
dslr, full frame, full-frame, k-1, k1, pentax k-1, video
K1 Live View Noise Gkiester Troubleshooting and Beginner Help 15 12-31-2016 01:14 PM
K1 video gnugent Pentax K-1 & K-1 II 2 07-04-2016 09:36 AM
K1 for video Roelf Wentholt Pentax DSLR Discussion 4 06-09-2016 05:48 AM
Live Feed Video? tcroxton Troubleshooting and Beginner Help 1 06-08-2016 06:28 AM
Pentax K1 / K3 Live View Depth of Field Preview sdgreen Troubleshooting and Beginner Help 12 05-20-2016 09:56 AM
All times are GMT -7. The time now is 03:30 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
