Originally posted by Abram I have tried fine tuning each lens, but sometimes the lenses back focus and sometimes they front focus.
As noted above, example photos are helpful.* A few questions:
- What are your expectations? What constitutes missed focus with your usual choice of subject?
- How are you assessing the need to do AF fine adjustment?
- Similarly, how do you confirm successful AF adjustment?
Do those questions sound silly? They sort of are, so I will clarify a little. Your signature includes two very fine quality rangefinder cameras, both of which are capable of extremely precise focus, though not with all subjects. Nailing focus on the front of a grapefruit at 1.5m may be difficult, for example. The sides are easy, but the front, not so much. Your K-1 has similar limitations relating to curved surfaces, receding surfaces, and the size of the AF point. As with your MP, your K-1 should be able to nail focus on a high contrast flat target at moderate distance, assuming proper calibration.
Whether the K-1 is as consistent in doing so as your MP, is another question. It is not unusual for PDAF (all brands) to indicate a focus variance of as much as a millimeter +/- of best effort using magnified live view when focusing with fast lenses at moderate distance. The ability to detect an out-of-focus state is the same with an f/1.4 lens as with an f/2.8 lens and with an f/2.8 lens is limited by DOF in much the same way as when focusing directly using an optical viewfinder. That being the case, for any number of focus attempts with an accurately calibrated system, a fair number will be back-focused and a similar number will be front-focused. For all but the most demanding tasks and at normal viewing distances/magnification, this precision is perfectly adequate at taking apertures f/2.8 and narrower.
I have reviewed your Web page and am impressed with your work. I can confidently state that you should be able to get similar results from your K-1 using the lenses you mentioned in your post. With any luck your examples will hold some clues as to what is awry.
* Unedited in-camera JPEG, linked from another site or cloud storage. Uploading to Pentax Forums strips the EXIF.
