Originally posted by boriscleto If you install the PEF codec. Viewers don't really read RAW files anyway. They mostly just display the JPEG preview. The exception would be FastRawViewer...
Faststone Image Viewer wll read raw files if you go into the settings and modify the raw tab's settings, or press the "A" key. Set the first two drop downs to on the RAW tab to "actual size - slow." And it is slow to load. I used this to extract and save one of the K-1's PS images from raw before I knew about DCRawPS's option to extract all four.
Now I use Raw Therapee for K-1 PS, as it has the best PS motion control options out there, including image brightness equalization of the 4 images, saveable visualization of the areas with motion, and the ability to choose which one of the 4 images is used for the motion correction.
Originally posted by BruceBanner My K-1 arrived today! I noticed it shoots .PEF in raw, I'm used to (and have codec support for) .DNG files, is there any difference between the two? They seem to take up the same amount of space/size...
Bruce,
Perhaps applicable to your original question: It appears that Adobe CS6 does modify my original DNGs when I make changes with camera raw. Have not been able to change that behavior to make it use XMP sidecar files as it did with older PEFs, even with the settings options in Bridge. Anyone else have a solution?
Reading K-1 PEFs is disabled/not supported in CS6, you have to use CC version. I assume that CCs behavior with DNG files is the same as CS6, but have not tried CC to verify. So modification of my DNG originals is the price I have to pay to use CS6 with the K1.
It is possible to use Adobe's DNG converter to convert PEF to DNG, and even embed the PEF into the DNG so it can be extracted later. Both options increase the use of storage space which the K-1 seems to slurp up anyway.
Don't know about LR6's behavior with K-1 DNGs, whether it modifies them or not. LR6 wil read K-1 PEFs and use XMP sidecars, I believe, but have not tried it, as use K-1 DNGs exclusively now.
Cheers!
Roger
