Wow... i feel a bit stupid now, for ages I have been using (on my K-50) the SMC-A 1.7 50mm and always controlling the aperture via the ring, i never noticed the green 'A' and how there's a little button there for you to press down and twist past F22 to get to the A! That's great, just tested with the K-1 and now I can control the aperture via the camera body
I still have option 26 'Using Aperture Ring' in the menu to being at point '2', do I no longer need to have that enabled if I am in 'A' position on the lens?
Off topic, but a curious thing happened as I was walking back home today (snapping pics of course). At some point, when I half pressed the shutter button it focused fine, then pressing fully down everything just kinda goes blank (optical viewfinder), and you need to press the shutter button a second time properly for the pic to be taken :S
It's like almost Bulb mode or summin, but the exposure doesn't change :S
I dunno what I did, I had to use the 'Reset' option in the menu to get things working again normally, what did I do?
