Thanks for the 2 replies.
I'm looking at this screen shot attached, of the K1 review posted , it shows 5 brackets at 1.5EV, can it then be set to an EV spread of 2.5 or does it stop at 2EV like on the K5...? I'm a little confused about this 3 EV spread... or does it mean 3 EV is only applicable to 3 brackets? It looks like all we need is a firmware update to enable 2.5EV - using the whole range from -5 to +5 at 2.5EV, like this:
-5 / -2.5 / 0 /+2.5 / +5 which enables an 11 EV spread instead of the 9 available so far. That would eliminate the use those fancy gizmos or even the aisle of doubling the brackets like I have been doing like this: #1: -4 / -2 / 0 /+2 / +5 and then #2: -2 /0 / +2 / +4 / +6 and getting rid of one set of -2 / 0 /+2 which gives you 7 brackets.
So, the rear wheel still only goes to 2EV maximum and not to 2.5EV.
Thanks again.
