04-02-2017, 05:47 PM   #1
K-1 bulb mode question
I have been struggling with the K-1 bulb mode, maybe somebody can help. I start the long exposure, and whatever time I chose for the exposure, the camera will afterwards count down that number of seconds or minutes. For example, if I chose an exposure time of two minutes, I will start the exposure and then stop it with the remote after 60 seconds, and then the camera starts to count down 60 seconds. Why does it do that? Does that mean I now have an exposure time of twice the amount, i.e. 120 seconds?
This is annoying because while it counts down, I can't do anything with the camera. If I have an exposure time of five minutes, I actually have to wait 10 minutes!
With any other camera, I do the long exposure, and after I click the shutter the second time, the exposure is done. What the Pentax does is confusing. Can someone please help??
04-02-2017, 06:02 PM   #2
Dark frame subtraction
It worried me at first too...
Have a read of this -Dark frame subtraction Dark-frame subtraction - Wikipedia
04-02-2017, 07:11 PM   #3
Otis Memorial Pentaxian
QuoteOriginally posted by mdurson Quote
QuoteOriginally posted by BROO Quote
Turn this off using the setting below
Rec Menu 2/Noise Reduction/Slow Shutter Speed NR
This may also be set using the "control panel".
BTW...Welcome to the Pentax Forums!
04-14-2017, 10:21 AM   #4
thank you, that helped!
04-14-2017, 10:21 AM   #5
thank you, that did it!
04-15-2017, 04:16 PM   #6
You might want to consider leaving this setting turned on particularly with longer exposures. Its annoying having to wait twice as long but the IQ results are better. If you have a second camera shoot that as well while the other is exposing.
04-15-2017, 08:37 PM   #7
QuoteOriginally posted by Gyroscope Quote
Hmmm, if it makes that much of a difference, I will turn it back on and check it out. Thanks for the input!
04-15-2017, 08:58 PM   #8
Wheatfield's Avatar
You can also get very good results doing noise reduction as part of processing the image.
04-17-2017, 11:02 AM   #9
You can also take some dark frames (Cover the lens with the lenscap and take a few shots at the same exposure and temp as your main shots) after the session and subtract them from the main image in some program that does dark fram subtraction (Deep sky stacker, Nebulosity, Pixinsight, Photoshop etc...). This way you maximize your time taking images.
04-18-2017, 09:00 AM   #10
MJKoski's Avatar
This setting can be programmed to the quick setting -panel! So it can be accessed with info-button anytime. Very handy for long exposure users. There are however exceptions to the rule - do not use it with pixel shift, it will ruin any detail advantage it gives. And you can also use multiexposure in-camera program to take, say, 100 shots and let camera compute one output RAW file from that. This will also smooth out moving parts like water. Averaging 100 shots gives so smooth file that dark frame subtraction is rarely needed for non-astro work.
05-09-2017, 01:51 PM   #11
Thanks to several users for their notes on this. I just joined specifically to check on this issue.
It does seem excissive. I like the idea of keeping a set of the dark images around to subtract on demand.
bulb, camera, count, dslr, exposure, full frame, full-frame, k-1, k-1 bulb mode, k1, minutes, mode, pentax k-1, time
Pentax K-3, Manual Mode won't switch to Av, Bulb, but stays in M Mode scotman55 Troubleshooting and Beginner Help 5 10-10-2022 07:17 AM
Bulb mode help jtkzoe Troubleshooting and Beginner Help 8 08-18-2016 05:23 PM
K-5 in bulb mode - interesting behaviour pathdoc Pentax K-5 & K-5 II 7 05-24-2016 02:48 AM
Bulb mode question Smilesy Pentax K-r 9 08-19-2012 08:22 PM
Night Bulb mode startrails.. a question really bergmania Post Your Photos! 2 12-02-2009 04:23 AM
All times are GMT -7. The time now is 08:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
