Originally posted by howieb101 That's one user comment, nobody else seems to be having the problem and even that member seems to be happy with 1.4 now.
Just try 1.4 for yourself. The issue he had related to lens adjustments he'd made. Then after loading 1.4 again as well as testing AF and doing minor changes, the AF functioned the same as in v1.3. This sounds like even this bloke is now using v1.4.
As mentioned in my first post there's some really good updates in 1.4 that are worth having. But if you're still not convinced just load v1.3 set up the camera with any lens adjustments. After that load v1.4. If there's any changes to AF lens adjustments do some changers like that poster did and you should be good to go. Don't like it? Roll back by loading v1.3 and crack on. You've bought the camera so as long as you're happy with it, that's the main thing.
Tas
