For CiF You need:
a) Turn off shutter priority
b) Select the right AF mode in camera (on some cameras it is AF.A, on some AF.S, check manual)
c) The lens mount must be conductive to short the AF contacts (lenses with fully plastic mount or with nonconductive coatings or lenses like Helios 44-2 that do not cover the contacts will not work)
d) Lens must be switched to MF. Lens with no AF is always MF. If lens is AF and there is no switch, like on most DA lenses, then you cannot CiF. Some users report that lenses with Focus Clamp can use CiF, as the clamp turns the lens to MF. I have not tested this personally, but it sounds interesting. Think about F or FA 100mm macro lens. Super sharp optics, decent price, and it should allow CiF, at least according to some reports
e) Camera must be set to AF (button near the lens mount). Check manual which AF setting, for those cameras that have multiple options
f) Enable CiF in Menu (near the end)
Now hold the shutter button and wait for something to get into focus, or twist the focus ring slowly until it hits something. This will trigger the shutter. You can even use burst mode with it.
CiF is great for old MF lenses. It is useless for modern lenses with no AF button. While you can push the mount release button on the camera, I would really advise against this.
Originally posted by RoccoStiglitz Camera mounted on a tripod, remote release with the button locked seems like it could be a good pseudo motion sensor kind of setup.
Maybe you can use something like Pentax M 50mm f1.7 or Pentax M 28mm f2.8 or even one of the medium telephoto primes from the film era. Most of these are super affordable with good image quality. The M50mm f1.7 is about as good as the DA 50mm f1.8, only it has older lens coatings so it is recommended to use a good tight lens hood on it. M 50mm f2 and lens hood should cost under $60. Cheaper than motion detection sensors
