Originally posted by mattt Hey folks
I've been playing with the K-1 Astro feature, after having been pretty functional with the OGPS-1. I preface the following by saying the manual is pretty vague - I looked but could not find any hint to my question below.
The menu buttons are pretty intuitive to make it go, I really like the quick access to the precise calibration, but I've been confused a little bit by the green button functionality. It seems it toggles Bulb mode and on board timer.
Is this feature so that someone can used a wired release with a timer?
I of would normally use the Astrotracer timer and a wireless remote. I've been a little confused as to whether the Astrotracer feature is actually engaged when the display shows "bulb".
TIA
Either the green button or exposure compensation button allows you to toggle the astrotracer while in bulb mode- I can't remember which, but you should see the astrotracer icon next to it, not the self timer icon. You will see the "B" icon replaced with the astrotracer icon on the status screen / in live view when the astrotracer is on.
The other button switches between standard bulb mode and timed bulb mode. With a recent firmware update, bulb mode now allows you to select shutter speeds >30s and <20minutes (this is what might be throwing you off). When the astrotracer is on, you should only be able to select shutter speeds <5minutes (sometimes less than that depending on the focal length/location).
PentaxForums.com Webmaster (
Site Usage Guide |
Site Help |
My Photography)
PentaxForums.com server and development costs are user-supported. You can help cover these costs by
donating or purchasing one of our
Pentax eBooks. Or, buy your photo gear from our affiliates,
Adorama,
B&H Photo,
KEH, or
Topaz Labs, and get
FREE Marketplace access - click here to see how! Trusted Pentax retailers:
