Originally posted by pschlute The way to get it to default to auto ISO is to make sure your K1 "memory settings" has "sensitivity" un-checked. Then every time you turn the camera on it will default to auto ISO.
This will be for all modes (except Sv)
I know this thread has been inactive for awhile but I wanted to thank you for posting this information. Recently my K-1 started defaulting to auto iso upon startup whereas before it had always retained the iso setting present at shutdown, which is my preference as I would rather not have to manually change the setting every time I restart the camera. I spent a huge amount of time going through the owners manual and my ebook k-1 manual but could find no way to change the iso setting from defaulting to auto. Finally I did a search on this forum for "iso default" and found this thread. Sure enough, the sensitivity setting was unchecked, apparently because I had inadvertently unchecked it recently. I checked "sensitivity" and problem solved.
From now on when I have such a problem with my K-1 I will search these forums first rather than as a last resort. The quantity of info here is incredible. But I'm wondering how did you know to do this when the info doesn't seem to be available in the expected sources (unless I missed it)?? Once again, thanks very much.
