Originally posted by pschlute I had the same worries when i first got the K1. After a proper focus test and adjustment for each individual lens, it never misses. I needed between +7/+10 on all my lenses
Download a focus test chart and print it.....
http://www.kscameraclub.org/docs/pdfs/focus_test_chart_edited.pdf
Camera on tripod, centre spot AF point only. Widest aperture. Before conducting each test get the lens to focus at infinity or closest point (a hand in front of the lens works quite well), so you are making the camera work each time to focus. You need to do about 10 tests with each lens after making any focus adjustment. A single test may not work...you will be surprised how varied the results of a focus lock can be...look at the barrel markings each time.
Also try to do the tests under natural light if you can.
You can do all the adjustments without having to view the photos on your computer, just zoom on ezch image....10x is 100% view
Ok, so I'm just getting round to doing this now. I'm wondering if I can seek further advice.
I dled the pdf file, printed page 15, mounted on cardboard and angled at 45 degrees as per instructions. I first noted that 45 degrees seemed a tad steep, other videos for AF testing seemed to have them shallower, perhaps half that?
I kept the tripod and camera fixed and changed the three lenses (that I have that AF), first was the DA F 100mm 2.8, second the DA 50mm 1.8, third the DA 21mm 3.2. I believe I adhered to the test protocols for each lens, that is to use a single centre spot for focus and to shoot wide as possible (so 2.8, 1.8 and 3.2 respectively).
Please see below for the results;
100mm 2.8
50mm 1.8
21mm 3.2 (shot full frame hence vignetting)
Now the first thing that comes to mind is, because I am using a fixed position for the camera its harder to critic the lenses? Should I be pushing the 21mm and 50mm lens closer to the sheet so that the piece of paper starts to occupy about the same visual representation as what I have with the 100mm? For example, of course zooming in with the DA21mm shot at 3.2 towards the black focus line is going to look garbled and awful, i'm having to crop far more to see that area!
Having said that, i did recall reading somewhere that shooting the DA21 at 3.2 is a pretty miserable experience, f8 is far better, and i did take a shot at f8 and can report that the sharpness is far better.
If i perform more of these tests, and I believe above the focus line appears more in focus, then which direction am I moving the +/- 10 scale in teh camera to compensate for this?
Basically I'm just looking for further guidance in performing these tests better before continuing and making any adjustments (if any are even required).
EDIT: I realise the images above are fixed, and don't become clickable links to the source, if you click my flickr signature they should be the first pics in my photostream (thereby allowing you to view the original files and zoom around)
