I took a look at the ES last night - only works in LV and shake reduction is disabled as indicated by the icon at the top of the LV image. I'm curious however, when the shutter is pressed, the screen goes black, then there's a noise almost like the mechanical shutter, the preview image comes up, and then after the preview period there's a noise like the mirror is being returned to it's normal position (although that can't be the case since the image goes back to a LV so the mirror must still be up). Both noises introduce some shock you can feel while holding the camera. Anyone know what these are? I assume both take place after the ES image is obtained so they shouldn't affect the image through vibration?????
Sorry - don't mean to hijack this thread but the question seemed closely enough related to the OPs inquiry about ES and since we're talking about use of the ES............
Also, in talking about the use of ES with the viewfinder, I don't think that's practical since the mirror would have to pop up creating a vibration prior to the ES doing its thing, negating the primary advantage of using the ES in the first place. If you have a delay between the mirror flip and the ES firing (so vibrations could die out), you would be out of luck for any moving action since the subject matter would change in that time (a problem in older digital cameras which captured images with a delay from the time the shutter button was pressed). When you're using LV, the ES can activate almost instantly, grabbing what is displayed on the screen and with no vibration at all (at least that's the idea).
