Originally posted by Bob 256 I haven't had my K-1 long so bear with me if this is a newby question. I noticed that the K-1 generates a new folder every so often. It seems that if I don't use the camera for a period of time, the next time I take pictures, they end up in a new folder. Can someone explain how this works? Also, if pictures taken are stored as DNG and JPEG (two cards), will deleting a given image delete both file types for that image (on the separate SD cards)? I also noted that deleted images end up in a folder of their own - they don't show up on camera preview but do show up if the card is read on a computer. Is that a trash bin of sorts? Any comments? Thanks.
I think that the camera creates a new directory daily, although sometimes it seems like it's every time you turn the camera on.
There is an option in the menus about creating a new directory, but I think that's for forcing the camera to create a new directory. (a good idea if you're doing several shoots in a session or a day.)
If you're looking at photos and hit the trashcan icon, it should ask if you want to delete the RAW, the JPG, or RAW+JPG.
I have not seen the behaviour of things ending up in a trash can folder when deleted... HOWEVER, I have noticed, that if you're recording all images to BOTH card slots, and you delete an image, it is only deleted from ONE card slot. This makes me think that if you're recording one image to each card, one RAW, one JPG, that it might only delete one when you're deleting, and the other may remain. Certainly an oversight in the deletion routines.
