Originally posted by Pixelhdr I have no problem using PDCU and I only use PDCU to process the raw files into TIFFs which are then imported into LR for additional adjustments.
I think this is a good method whenever you are using more than one software. You do the first steps, like lens profile correction, PS stuff, CA correction, maybe even noise reduction and things like cloning out dust spots in the first software, then export as 16 bit tiff (usually its best to use tiff without compression, as some software can't open compressed tiff files), and then open that tiff in the next software.
I don't have a PS camera, but that's what I do when using plugins or going between LR and RawTherapee and so on.
RawTherapee is pretty nice, even though its a bit more complicated to use than LR.
