- So you cant change into self timer or continous shooting aswell? - that's correct, I can't get into the drive mode in order to change to any of the options there.
- Are your AF point changing when pressing UP? When I am in the [auto33] mode no. In the [auto9] and [sel] modes, yes - I can move the selection group/point around using the arrow keys.
- Press the little button next to the UP button and try again... The [-|-] button? That was it!!! Who would of thought? I guess I hit that button by mistake out in the dark when I was out in the field during one of the last few outings.
---------- Post added 10-14-17 at 01:47 PM ----------
Originally posted by Adam If you've set C20, then you'll need to press the AF point selection button before the 4-way controller gets unlocked. The status screen should show you the current role of the different buttons.
Also, if you set the settings dial to bracketing, you can easily switch in and out of bracketing using it.
... it was the "Change AF Point/Card Switch Button". I really never change AF points, so that would have been the last thing that I would have ever consider. Must have hit the button out in the dark.
---------- Post added 10-14-17 at 02:04 PM ----------
Thanks - All !!!! I now think that I had read sometime in the past about this button - anyway, it's now seared into my memory.
