02-06-2018, 06:23 AM   #1
Pentax 400-600 Mirror lens on K-1
I have tried the 400-600 Pentax Mirror lens on my Pentax K-1, but the camera refuses to work. On the display F-- flashes, and the camera wonŽt fire. I understand, that the lens camera contacts are short-circuited (the lens has no contacts). How can I get the K-1 to work with this lens ? Any idea would be greatly appreciated.
02-06-2018, 06:53 AM   #2
boriscleto's Avatar
Have you set 'Using Aperture Ring' to 'Permitted' in the Custom menu?
02-06-2018, 07:41 AM   #3
pschlute's Avatar
You may have to change that setting as boriscleto advised, even though that mirror lens is a constant f8. Use Av or Manual exposure mode.
02-06-2018, 08:28 AM   #4
QuoteOriginally posted by boriscleto Quote
No I didnŽt. Maybe this is the culprit. IŽll try it out. Thanks for the help !
---------- Post added 02-06-18 at 08:31 AM ----------
In the manual mode it didnŽt work too. IŽll try the boriscleto method. Thanks !
02-06-2018, 09:38 AM   #5
Don't expect to get an f stop reading with any method. Although the F-- flashes, the camera should take a picture. I had that issue with a manual lens until I the preceding settings were suggested here. The K-1 may also ask for the focal length the first time the lens is used. Another issue is if the AF is turned on (it should be in manual focus for this lens) and a sharp focus isn't achieved, the camera may not fire.
02-06-2018, 09:42 AM - 2 Likes   #6
You have to change the aperture ring setting first. Then, since the aperture value never changes, you can use Av mode to meter, as if this were an M42 lens.
See this thread:
How to use/meter Manual & M42 Lenses on all Pentax DSLRs (K-1, K-3, K-5, K-30, etc) - PentaxForums.com
02-07-2018, 08:13 AM   #7
QuoteOriginally posted by Bob 256 Quote
Possible, this is that ! The sharp focus was not achieved, I will play with the focus again. The AF-switch was on M, therefore. Thanks for the help !
02-07-2018, 09:43 AM   #8
QuoteOriginally posted by adam49 Quote
There's an override in the menu for the focus lock, I believe, which would allow the shutter to trip even if a sharp focus isn't achieved.
02-08-2018, 12:27 AM   #9
Yes, but if "F--" flashes, the shutter wonŽt work. It have to be the C4 menu setting. Thanks !
camera, contacts, dslr, full frame, full-frame, k-1, k1, lens, mirror, mirror lens, pentax, pentax 400-600 mirror, pentax 400-600 mirror k-1, pentax k-1, thanks
Where to get accessories for the FA* 300/2.8, FA* 600/4, FA* 250-600, A* 400/2.8, etc Clinton Pentax SLR Lens Discussion 28 07-13-2023 12:07 AM
Simple lens shootout Pentax HD DFA 150-450 vs Canon 100-400 II vs Sigma 150-600 C beholder3 Pentax SLR Lens Discussion 46 07-25-2016 12:33 AM
All times are GMT -7. The time now is 06:51 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
