Originally posted by keos F-stop is f-stop, ...
"F-stop is f-stop" is true in the same sense as "Focal length is focal length". Correct, from a certain perspective (physical attributes of a lens don't change, regardless of sensor size), however, incorrect when considering the effect of an attribute, such as f-stop or focal length, on the image, depending on format size.
Originally posted by keos If you take an exposure with a certain f-stop and shutter speed, at a set iso, it will meter the image in a certain way, regardless of how much of the film you cut.
Correct.
Originally posted by keos Let's say for the the sake of this experiment that this is iso-400 film, metered at f2.8 with 1/60 shutter. If you cut out the sides of the developed film so you've cropped by a factor equivalent to an angle of view that is equivalent of 1.6x your focal length, you've created an aps-c crop. The image won't magically darken.
Yes, the image will not "magically darken".
However, remember that your film will be the negative (once developed). Now imagine to produce the same image on photographic paper, once using the full negative (FF) and once using a cropped negative (APS-C). You won't be able to. Larger negatives yield better quality images (less noise). That's the whole point of large format photography.
Note that the "cutting sides off" approach is not helpful in making useful comparisons. If you cut sides off a negative and then develop with an unchanged enlargement factor then you'll get a crop of the original image. This crop will be identical in quality to the crop you'd get by cutting sides off the photographic paper, but you can hardly compare two photographic prints where one has twice the size and shows more of the scene, can you?
If you attempt to get the same/similar information into the smaller negative (by using a wider lens, or "standing back") then you will have to use a bigger enlargement factor in order to get the same photographic print as you can get from the original FF negative. The bigger enlargement factor results in more noise in the photographic print. N.B., only using a wider lens (with the f-stop adjusted by a divisor of 1.5) will give you the same information. "Standing back" will result in a different perspective and different DOF.
The enlargement factor (which is higher when using APS-C compared to FF) is easily forgotten about when talking about digital photography, but as soon as you print the same image to a given output format (say 16x20) then you'll notice that capture format (film size or sensor size) does matter.
This is not a straightforward topic. In order to not derail the thread, I'll only say that "f-stop is f-stop" is not a correct statement in every sense of the phrase, just like "focal length is focal length" is not a correct statement in every sense of the phrase.
