02-28-2018, 01:11 PM   #1
External power
Say I want to do a long period time lapses, can anyone point me to an external power sources that will work with K1?
02-28-2018, 01:18 PM   #2
This is the adapter for the K-1:
Pentax K-AC132 AC Adapter Kit 38780 B&H Photo Video
02-28-2018, 01:33 PM   #3
Older DC adapters for K5 and K7 will do fine too. Try Ebay
02-28-2018, 01:53 PM   #4
Thanks guys - went to ebay, saved $80 off B&H (sort of)
03-01-2018, 12:25 AM   #5
Not a Number's Avatar
It's my understanding from past posts that all the AC adapters (at least from the K10D on) are interchangeable. For the bodies that don't have a jack there is an adapter that replaces the battery.
There are also 3rd party adapters.
03-03-2018, 01:55 PM   #6
angerdan's Avatar
There's even a name for the plug: Hirose MQ172-3SA-CV(50)
Pentax AC Adaptor Kit K-AC50U - PentaxForums.com
AC adapter D-AC 50 - PentaxForums.com
All the Pentax DSLRs with an AC port from the K10D on and the K-01 use the same connector and 8.3v input.
MQ172-3SA-CV(50) Hirose Electric Co Ltd | Connectors, Interconnects | DigiKey
03-06-2018, 11:25 PM - 1 Like   #7
Make your own?
If you're handy with a soldering iron and can read schematics, you might want to check this out: DIY AC Adapter for The Pentax K10D and K20D | The Roaming Drone I use 2 of these daily to shoot hummingbirds, dawn to dusk, powered by 12v batteries for UPSs.
03-07-2018, 06:09 AM   #8
Since I don't use one very often, I have found this one seems to work fine. The only Negative review was that it didn't charge the battery in the camera which is not how Pentax works anyway. $11.91 on Amazon.
https://www.amazon.com/HQRP-Adapter-Pentax-K-AC132-Digital/dp/B00RGSSTIO?tag=pentaxforums-20&
03-07-2018, 01:23 PM   #9
The question that arises now is: "Do you trust a no-name manufacturer sold by Amazon to create a product that surely won't damage your camera?"
Amazon's track record in selling counterfeit and in some cases really dangerous products would make me wary of such an offering.
03-13-2018, 12:42 PM   #10
smigol's Avatar
QuoteOriginally posted by iCrop Quote
I agree on this solution. I had a friend make two of these for me several years ago and they are still working perfectly when I do long exposure work.
10-03-2019, 11:07 AM   #11
QuoteOriginally posted by smigol Quote
Are you using this to power the K-1 with 12vdc?
dslr, full frame, full-frame, k-1, k1, pentax k-1, power
Pentax K3II above the serial number for power off issue has had power off issue Azhure Pentax K-3 & K-3 II 3 04-10-2017 03:23 PM
Pentax external power supply voltage tolerances beholder3 Pentax DSLR Discussion 9 02-16-2017 05:56 AM
DIY External Power Cable for 500FTZ vuacorona Pentax Camera and Field Accessories 2 11-16-2014 05:47 AM
Travel external order and external disorder there's only the seeming phenomenon zztopd Post Your Photos! 11 02-17-2014 09:47 PM
For Sale - Sold: two Pentax TR Power Pack-2 (external flash power) yurihuta Sold Items 2 03-13-2013 07:59 AM
All times are GMT -7. The time now is 11:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
