03-10-2018, 05:22 PM   #1
KA5TXL's Avatar
Problem with the B setting and the Pentax shutter release cable
When I put my K1 in "B" mode and try and use the Pentax shutter release cable it activates the shutter at somewhere around 1/125th, which when I press the shutter release on camera I get the same result. I have ruled out a problem with the cable as it works fine when I try it with my K20D. The K1 and the cable worked just fine in "B" mode last fall but that was before I upgraded the firmware. Any suggestions?
03-10-2018, 05:33 PM   #2
photoptimist's Avatar
Check the Bulb Mode Options in menu C1.
03-10-2018, 05:58 PM   #3
Ex Finn.'s Avatar
Just tried wired shutter in B with FW 1.43 works OK. So it should not be a problem with firmware.
03-10-2018, 09:29 PM   #4
KA5TXL's Avatar
Thanks, I tried both options but it did not clear the problem. I have also done a reset but no change
03-10-2018, 09:31 PM   #5
If you're getting the same result with the shutter release on the camera, it isn't the cable but the camera itself (as you verified by trying the cable on another camera). Check the menu as photoptimist suggested. Also, this might be a dumb suggestion but check to make sure you're in bulb mode. It should show on the rear LCD (upper left - "Bulb"). Lastly, make sure your battery is up to snuff. If it's near the end of it's life, firing the shutter in bulb mode might be just enough to make the camera think the battery is dead or dying and shut down leading to a short exposure. Keeping the shutter open draws a bit more current and might be just enough to cause this issue if the battery is marginal.
03-11-2018, 12:25 PM - 1 Like   #6
KA5TXL's Avatar
QuoteOriginally posted by Bob 256 Quote
Thanks everyone I have solved the issue, apparently my fat fingers had previously hit the EV button and knocked it off of 0.0, any value other than that will prevent B operation
cable, dslr, full frame, full-frame, k-1, k1, mode, pentax, pentax k-1, pentax shutter release, release, shutter
Pentax 67 Cable Release Problem claudechar3 Pentax Medium Format 7 08-08-2017 04:59 PM
Shutter release: IR and cable, waiting for a Wi-Fi solution for Win/Mac cyberjunkie Pentax K-1 & K-1 II 11 11-04-2016 02:16 PM
Shutter release cable for the K-1 AwesomeIan Pentax K-1 & K-1 II 8 07-06-2016 02:40 PM
Suggestions for remote shutter release cable / remote Sean Hamilton Troubleshooting and Beginner Help 8 06-09-2016 07:15 AM
DIY DSLR K-X “Cable” Cable Release trailrider Do-It-Yourself 4 07-11-2012 10:18 PM
All times are GMT -7. The time now is 06:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
