I know that most of you shoot in RAW and then spend a huge amount of time in post processing, but I'm not the kind of person who wants to spend time after taking photos.
On special trips I shoot both JPG+RAW just in case I need strong correction on the sky and/or on the shadows, but having several in-camera option settings for dynamic range and a circular polarizer always attached, I don't see the point in post processing. I want it simple and save time, therefore: JPGs.
Here my general settings with a Zeiss Distagon T* 2/28 (with the 2/35 and 2.8/25 same but EV: -0.7 to -0.3) plus specific settings for my two most used image modes:
GENERAL SETTINGS:
- ISO: 100 (to avoid noise and ensure maximum quality)
- EV: -0.3 (to 0)
- Highlight Correction: Auto
- Shadow Correction: Auto
- Shake Reduction: Off (to minimize blur images)
- JPG Recorded Pixels: L
- Clarity: +4 (in my opinion this parameter is a must and keeping it at its maximum value, otherwise the images look flat with the default value "0", however it takes time to process/save data with whatever value different from "0")
BRIGHT (my favourite image mode):
- Saturation: 0 (to +1)
- Hue: 0
- High/Low: 0
- Contrast: +1 (to 0)
- Highlight Adj: 0
- Shadow Adj: 0
- Sharpness Fine: +4
LANDSCAPE:
- Saturation: -1 (to 0)
- Hue: 0
- High/Low: 0
- Highlight Adj: 0
- Shadow Adj: 0
It's somehow confusing when it comes to Dynamic Range adjustments, as the camera has DR settings in three different locations:
*** In the "INFO" menu:
- Highlight Correction: Auto / Off
- Shadow Correction: Auto / 1 / 2 / 3 / Off
*** In the Image Mode menu:
- Highlight Adjustment: -4 to +4
- Shadow Adjustment: -4 to +4
*** In the HDR menu:
- Auto
- 1
- 2
- 3
- ADV
- Off
Are these parameters:
the same than the following ones?:
Why this confusion? What is the difference between the first two and the following two and why different value settings? Do these four parameters with their settings overlap (i.e. Shadow Correction "3" plus Shadow Adjustment "+4" deliver stronger effect than Shadow Correction "3" plus Shadow Adjustment "0") or does the camera take one parameter instead of the other? All this is so confusing...
I'd appreciate you to share your image settings and also to respond my confusion about the apparent same DR parameters located in different menus and with different value settings.
Thank you all.
